Projects LPRS Sedan Delivery Build Thread
Discussion in 'The Hokey Ass Message Board' started by LPRS, Feb 20, 2014.
  1. LPRS
    LPRS
    Well, here goes nothing. Ive lurked on here for years and occasionally comment, but never really had anything hamb worthy of contributing. Unfortunately this build is going to go a little slow for most of your liking, but I think the pressure from you********s might just keep me on task. In between farming and off topic fab projects, I came across this Thames E300. It was hot rodded on the cheap back in the late '70s by cutting the middle of the unibody out and stick welding some***** togther to fit a 350/350 to 10 bolt combo.
    1927graham likes this.
  2. LPRS
    LPRS
    Structural C Channel for crossmembers and the left over bent up floor and unibody had to go. Plans became cut out all of the floor/unstructured and build the car into a full frame car. Add in the remnants of an old Vega race car and the idea starts taking shape.
  3. LPRS
    LPRS
    Came up with the concept of a mild gasser stance, sbc/powerglide/narrowed 12 bolt, straight axle front combo.
  4. Okie Pete
    Okie Pete
    It will make one fast pizza delivery buggy. Kool build.
  5. fleet-master
    fleet-master
    I love these vans !! I have pics saved from the net of all my favourites :)
    Looking forward to following along
    subscribed
  6. LPRS
    LPRS
    I really like this one, swiped from the hamb:
  7. LPRS
    LPRS
    Managed to cut out the entire front floor and front clip in one shot. Then I built a frame and stopped working on the car for a year.
  8. LPRS
    LPRS
    Started back on it again in Jan. Cut out the rear flooring while leaving some of the bracing to keep the body rigid and mocked up the body onto the frame to get a better idea of what the hell to do next.
    kiwijeff and 1927graham like this.
  9. LPRS
    LPRS
    Had an idea last week to clean up the front end: ditch the stock head lights in favor of some vertically mounted t-bird quad headlights.
  10. LPRS
    LPRS
    More inspiration to get me through the weekend ... also swiped from the hamb:
  11. redzula
    redzula
    Good start to a pretty funky looking car haha. Its definitely cool though. I like the headlight idea. Good luck with the rest of the build.
  12. AHotRod
    AHotRod
    Stay on it..... it's going to be cool.
  13. LPRS
    LPRS
    Thanks guys
  14. 56sedandelivery
    56sedandelivery
    I like the whole concept, EXCEPT, if this is mostly a street car, then at least use a TH350. Powerglides are fine for the strip, but really boring on the street; at least in my experience. I build Glides for the local bracket racers, and we even used one of my Glides in my nephews 51 Bus coupe, and it really needs that "extra" gear to smooth things out. JMO. Butch/56sedandelivery.
  15. LPRS
    LPRS
    Collecting parts and refining the build a little. Just picked up a .030 over 4 bolt main sbc with an edelbrock intake and a Holley carb. Might have a lead on a t5 instead of an auto.
  16. LPRS
    LPRS
    Mocked the car up at ride height to get started on a new frame to change the stance and attitude of the car.
  17. LPRS
    LPRS
    Cut, drill, sand ...
  18. LPRS
    LPRS
    Fit, tack, weld ...
  19. LPRS
    LPRS
    Bracing up the body ...
  20. LPRS
    LPRS
    All tig welded ...
  21. LPRS
    LPRS
    A shot of the shop ...
  22. LPRS
    LPRS
    Some chassis welding ...
  23. LPRS
    LPRS
    The direction I'm going with the new chassis ...
  24. LPRS
    LPRS
    Front frame details ...
  25. fleet-master
    fleet-master
    great work LPRS !!
  26. LPRS
    LPRS
  27. LPRS
    LPRS
    Sketched out the rear kickup and some ideas for the fishplates ...
  28. LPRS
    LPRS
    Threw the motor on some blocks to get an idea of how it'll sit in the chassis
  29. LPRS
    LPRS
    Lets try that again
  30. LPRS
    LPRS
    Sketching out some draft shaft loop details.
