LS7 454 Crate Engine - Fresh, Standard Bore, Unassembled
Discussion in 'Parts For Sale' started by Wildman1, Jun 14, 2018.
  1. Wildman1
    Wildman1
    City: Portage Co
    State: Ohio
    Price: 3950
    SOLD! Thanks
    LS7 454 Crate Engine - Fresh, Standard Bore, Un***embled
    Fresh Std Bore Chevy 454 4 Bolt Block, Magnafluxed (no cracks) w/ New Cam Bearings & Freeze Plugs
    Correct GM Forged Steel Crank, Magnafluxed (no cracks)
    Std Bore Chevy 454 LS7 12.5:1 GM Pistons / 7/16in Dimple Rods w/ New Pins & Rod Bolts
    Factory LS7 Oil Pan
    Pair of Chevy LS7 Heads #6272990 - verified "like new", dis***embled
    Full set of Chevy LS7 Valves, Springs, Seals & Rocker Arms
    Full Set GM LS7 NOS Valve Springs, Cap & Seals - NOS
    GM Corvette Chrome Valve Covers
    GlassThamesDoug likes this.
  2. Wildman1
    Wildman1
  3. Wildman1
    Wildman1
    Weekend Special - $3800 !!!!
  4. Wildman1
    Wildman1
  5. Wildman1
    Wildman1
  6. Wildman1
    Wildman1
  7. Wildman1
    Wildman1
  8. Wildman1
    Wildman1
  9. Wildman1
    Wildman1
    B M
    U P !!!!!
  10. Wildman1
    Wildman1
    REDUCED!
    $3500
  11. Wildman1
    Wildman1
    SOLD !!!!!
    Here are some more details:
    I planned on using this set-up as the powerplant for a '55 Chevy pure race G***er, but an unexpected life event stopped those plans.
    As a result, I am offering for sale the following un***embled Factory High Performance BBC
    This is a Factory Standard Bore Chevrolet 454 4 Bolt Main Block w/ new Cam Bearings & Freeze Plugs, untouched since Magnafluxed & Prepped by Randy @ Center Automotive of Akron, Ohio in 2012. Block Casting # 14015445, Block Date Code L (December) 11 (Date) 8 (1978)
    Actual Factory Chevrolet LS-7 454 components also spec checked & balanced/blueprinted by Center include:
    • Correct Chevrolet 454 LS-7 Forged Steel Crank, Magnafluxed - turned .020, .010
    • Factory Standard Bore Chevrolet 454 LS-7 12.5:1 Pistons / 7/16in Dimple Rods w/ New Pins & Rod Bolts
    • Factory Chevrolet 454 LS-7 Oil Pan
    • Pair of Factory Chevrolet 454 LS-7 Heads #6272990 - verified "like new" by Center, dis***embled
    • Full set of Factory Chevrolet 454 LS-7 Valves, Springs, Seals & Rocker Arms - verified "like new" by Center
    • Pair of Factory Chevrolet Corvette BBC Valve Covers
    • Several NOS Chevrolet 454 LS-7 Valve Springs, Caps & Seals
    I am offering this package as listed - see photos for machine work/ engine specs by Center Automotive
    You would easily have to spend $5000 to get to this point
    $3000 Firm - Pickup at zip 44412 ONLY
