Lt-1 Short Block Value
Discussion in 'The Hokey Ass Message Board' started by JereStahl, Sep 14, 2009.
  1. JereStahl
    JereStahl
    from York, Pa
    I have a 1970 type Chevy LT-1 new short block that was recently clearance checked, fresh hone and assembled in NC that does R&D work for Chevrolet. (At least used to before O). I have no idea what it is worth. Any suggestions ?
  2. You might need to supply more information than that. Stock cam? Stock bore and stroke? Pistons? A 1970 LT1 block is just a four bolt common block. Its what is put into it for the total over all build that makes it what it is.
  3. oldchevyseller
    oldchevyseller
    from mankato mn
  4. Steves32
    Steves32
    from So Cal
    Curious- are you the Jere Stahl from Stahl Engineering & then Stahl Headers?
  5. zora
    zora
    from Seattle
    Is it a 3970010 '70 dated, 4-bolt block? If so, what are the numbers (date code and stamp pad). I might be interested...
  6. 49ratfink
    49ratfink
    not if you are a Corvette weenie. it's all about the numbers
  7. more info needed:
    especially date code on the back of the block, suffix code stamp on the front pad and build specs
  8. LT1 "TYPE" "NEW" short block...I doubt its a tagged original.
