Technical Lubricate Posie Super Slide
Discussion in 'The Hokey Ass Message Board' started by LongT, May 27, 2020.
  1. LongT
    LongT
    Putting a Posie Super Slide front spring. I removed it to put in a dropped axle, '39 Ford. Should there be any lube at the nylon bushings for the shackles or the "pucks". When I took it apart it didn't look like there was any lube there. But the car was a project not driven.
  2. Dan Hay
    Dan Hay
    No.
    LongT likes this.
  3. LongT
    LongT
    Thanks. I looked at the shackles. They are Pete and Jake's and have urethane bushings not nylon like the "pucks". Should they get lubrication?
  4. ct1932ford
    ct1932ford
    If anything I would only use a dry type silicone spray lube.
