Just wondering if anyone runs Lucas oil stabilizer in there air compressor? I just put new valves and rings in my mid eighties ir t30 compressor and was wondering about it. Any thoughts ars appreciated. Thanks Brian Sent from my iPhone using The H.A.M.B. mobile app
you should not put any additives in a compressors oil , compressor oil is straight weight, non detergent oils , partially to prevent coking of the rings and valves .
My compressor locked up yesterday. Low oil seized the crank bearing. I could kick myself in the ass, been a while since i checked it. Cheaper to buy a new pump than rebuild it
I use synthetic in mine. It runs smoother and faster due to less friction. In 5 years have had no problems.
Champion brand air compressor manufacturer offers both conventional and synthetic type pump oils. A recent conversation I had with a Champion dealer recommended to use non-detergent 30 weight oil if the Champion oil wasn't available. Just as an example of what one compressor manufacturer sells. I like Lucas and I use it and sell it. I wouldn't use it in an air compressor application.
Thanks to this thread I went and checked the oil in my compressors. Everything OK, but it had been a while since I looked.
Had an old 30 gallon Craftsman compressor that started knocking. I had already bought a new 60 gallon upright. So I drained the oil and put some 85-140 gear oil in it and gave it to my neighbor. I told him about the knock and said he would run it until it died and then replace the compressor. 2 years later that old compressor was still knocking and still pumping up tires and running a blow gun. My neighbor was in his 80's and fixed lawn mowers.
if its been more than a year or two and you use it often or its brownish black , change it . my friend has a compressor his grandpa owned ( Ingersol) thats never been gone thru other than valves ( unloading type ) because the oil is changed regularly , but I know of a shop near me that has gone thru several compressor pumps in 3 years due to lack of maintaince , ( black or non existant oil )
