Lug nut type for 36 wires
Discussion in 'The Hokey Ass Message Board' started by Crazy8, Aug 30, 2009.
  1. Crazy8
    Crazy8
    from KY
    Is there a certain type of lug nut for a 36 Ford wire? I tried some normal conical nuts and they dont seem to cover the are very wheel around the opening.
  2. HotRodFreak
    HotRodFreak
    I have no problem with mine on two cars.
  3. R Pope
    R Pope
    '36 wires???? I think you mean '35's. '47 Ford nuts work. Well-used wheels might have enlarged holes. I don't know what you'd do then. Weld 'em up, maybe?
  4. dudley32
    dudley32
    must be 35's..36 is wide five..just for info
  5. Ford used the same lug nuts from '28 until they went metric. The problem is that the lug holes on old Ford wire wheels are often wallowed out.
  6. Andy
    Andy
    You probably need some support rings so the wheels will tighten down right. Please PM me as I have some for sale.
  7. Try over sized stock lug nuts stock car suppliers like Speedway sells. They take a larger socket because they have more material on the taper and should help with worn holes in the centers.
  8. no55mad
    no55mad
    There are washers available. I bought some from 'Old Ford Parts' in Campbell Ca.
  9. FWIW, most '36s came with wide five wheels but a handful of very early '36s had '35 hubs and wheels.
