Lunar Lander Progress?
Discussion in 'The Hokey Ass Message Board' started by Plowboy, Jan 10, 2005.
  1. Plowboy
    Plowboy
    No, Not really, but I can lean a bunch of crap together to make it look like I am doing something! [​IMG]
    With Christmas and all the gatherings I have had to go to progress has been slow. I haven't been feeling too motivated some days either. I have been doing some drinking out in the garage though!
    I built the frame last thursday night. I used 1/8 wall 2x4 square tubing and a stock A crossmember.
    I tapered the framerails by cutting out a wedge of material and squishing the tube back down and welding it. I used a template that I made from a stock A frame and a plasma cutter to do this.
    I haven't z'd the frame yet because I want to see how low it is going to sit first. I plan on getting the spring mounted in the wishbones and the bungs welded in and mounted this week if all goes well.
    I will just start at the front and work my way back until everything sits where I want it.
    I also nothced out the body to fit over the frame. I have not cut the framerails at the back yet because I am not sure if I need some length for the Z yet. Like I said, front to back.
  2. Plowboy
    Plowboy
    Here is a little better pic of the front.
    I want the axle just in front of the grille. The spring will get mounted about 8 inches back in the wishbone.
    Since this thing will not have any doors I want it to be low. I am going to try and get the scrub line about 4 inches off the ground if at all possible.
    I was wanting to go with some cheater slicks on the rear but I am having some clearance issues and I need to use some wheels with little to no backspace so I may go with some tall skinny whitewalls. ! would like to have the tires taller than the body anyway. you know how people like that on e-bay! [​IMG]
  3. briggs&strattonChev
    briggs&strattonChev
    frame looks neat in the front
    what is that grille from?
  4. beatnik
    beatnik
    Looks great Aaron! One thing to think about is the radiator, sitting that low I had a hard time getting mine under the grill shell and still having the grill shell at a good height compared to the cowl.
    Cheater slicks would fit the style of the build better, but I'm sure what ever you do it will look right in the end.
  5. Elrod
    Elrod
    From that side angle it looked like you were going to have closed fenders on the back and open wheel on the front. But then the front picture showed that those aren't fenders sticking out from the body.
    Looks interesting.
  6. Plowboy
    Plowboy
    Gus, that is one of the things that I was drinking and thinking on. The good thing about that 34 Olds grille is that it is thick and I can probably put the radiator behind the crossmember and still have the grille cover it. I plan on using an electric fan to take care of moving enough air through it.
  7. TINGLER
    TINGLER
    They'll never let you into the Hunnert Car pile-up with that. [​IMG]
    Just joking.
    The Lunar Lander is gonna rock. Have you thought of any colors for it yet?
    (I want to build one now.....hmmmm...)
  8. Tuck
    Tuck
    Tech Editor
    from MINNESOTA
    1. Early Hemi Tech
  9. bobbleed
    bobbleed
    from Awesome
    Is 1/8 inch tubing heavy enough? Seems like you should use 3/16......
  10. Plowboy
    Plowboy
    My buddy makes chassis for race cars and works on Lolas and Ferraris. He seemed to think 1/8 (.125) was plenty heavy. A stock A frame is only 1/8 and most people box with 1/8 so it seems to me that it will be plenty strong, especially after all the crossmembers are in it and all.
    It will at least be as strong as a boxed A frame.
  11. 1/8 inch is fine if you're using 4130 Chrome Moly (as what's used in race cars).
  12. kustombuilder
    kustombuilder
    from Novi, MI
    thats lookin pretty wild bro. can't wait to see more.
  13. kustombuilder
    kustombuilder
    from Novi, MI
    whatcha runnin for a grill shell there holmes??
  14. zman
    zman
    from Garner, NC
    I'm digging it, still. Can't wait to see it done.
  15. yngrodder
    yngrodder
    The shell is 34 olds,
  16. kustombuilder
    kustombuilder
    from Novi, MI
    [ QUOTE ]
    [/ QUOTE ]
    my one ton crew cab dually has a 3/16" C frame. i've used 14gauge 2x4 (i think 1/8" is about 12ga) tubing quite a bit on some back halved air ride equiped trucks that see some severe abuse from the yahoo owners playin with the bags, and they have held up fine. the guy at the steel place told me alot of roundy round guys use the 14ga 2x4 tubing all the time, thats why i decided it was ok to use. proper crossmember go a long way to making it strong.
  17. bobbleed
    bobbleed
    from Awesome
    It seems to me the thinner tubing would have more of a chance of fatigue and cracking next to welds...
    It will probably work fine, but I would use the thicker stuff.
  18. haring
    haring
    That is crazy.
    This is the first time I'm seeing the whole body and not just the rear. I'm not sure if it's the first time you've revealed the whole thing, but it sure is wild.
    Do you have a clear vision of this thing as a whole? I'm seeing it as a 60s show rod, with bubbletop, wheel fairings and lots of flake. What are your plans?
