Technical Lycoming Straight Eight ID
Discussion in 'The Hokey Ass Message Board' started by Locomotive Breath, Apr 8, 2025.
  1. Locomotive Breath
    Locomotive Breath
    from Texas
    Can anyone help ID this Lycoming engine I just picked up?
    It's a big Lycoming straight eight. Obviously it was a stationary application, my guess is an irrigation pump as it came from a farmers barn. The intake and exhaust are made together. Uses a small updraft carburetor that bolts directly to the manifold log. The head is about 38" long and the engine itself is about 54" not including the PTO drive unit.
    IMG_20250405_174706588.jpg Screenshot_20250406-125503.Messenger.jpg Screenshot_20250406-125503.Messenger.jpg Screenshot_20250406-125453.Messenger.jpg Screenshot_20250406-125445.Messenger.jpg Screenshot_20250406-125440.Messenger.jpg Screenshot_20250406-125433.Messenger.jpg Screenshot_20250406-125424.Messenger.jpg IMG_20250405_174417072.jpg IMG_20250405_174706588.jpg
    CSPIDY, 41 GMC K-18, Stooge and 2 others like this.
  2. TCTND
    TCTND
    That could be great powerplant for the right boat.
  3. Locomotive Breath
    Locomotive Breath
    from Texas
    Thinking about using it in my '38 Dodge truck.
  4. '29 Gizmo
    '29 Gizmo
    from UK
    Same block as the 1930 Cord maybe.
  5. HEATHEN
    HEATHEN
    from SIDNEY, NY
    Mallory distributor; MUST be a high performance engine!
    seb fontana likes this.
  6. SR100
    SR100
    What are the casting marks visible at the bottom of the fourth picture? Is there any data on the plate on the top of the bellhousing in the ninth pic?
    If it was originally a stationary unit, it would have had a governor (probably removed when the Mallory was installed). Are there any signs (extraneous brackets, empty tapped holes, etc.) that a governor was removed?
    If you compare the number on the distributor to the Mallory distributor list, it may tell you what the original application was. I only saw one Lycoming: no. 187, a marine engine. Lycoming sold engines to a number of car and truck manufacturers, so it may be listed by that make.
  7. saltflats
    saltflats
    from Missouri
    Quit the oil pan on that thing.
  8. Hot Rods Ta Hell
    Hot Rods Ta Hell
    Cool looking mill! Does it turn over? If it spent it's entire life on the farm I'm guessing it might have low hours on it.
    I see that thing painted a very dark blue or green and detailed to the max with all the small parts (side plates, plug wire tube, acorn nuts, etc.) chrome plated (ala Duesenberg) and the starter, generator etc. painted gloss black.
    Would look great in a hoodless, stretched out roadster.
    Or bust it off as is and stuff it in a TROG build style Model A roadster. Just pull the firewall and set those last 2 cylinders right back under the cowl...
  9. Beanscoot
    Beanscoot
    How much does that monster weigh?
    It looks like there's a lot of possibilities to remove / replace big heavy cast iron pieces.
  10. oldolds
    oldolds
  11. Beanscoot
    Beanscoot
    Doesn't look like they support the I-8 anymore.
    41 GMC K-18 likes this.
  12. mamllc
    mamllc
    Is that a water cooled exhaust manifold? Was it a marine application?
  13. oldolds
    oldolds
  14. 41 GMC K-18
    41 GMC K-18
    Hey @Locomotive Breath
    That is indeed a very cool vintage LYCOMING straight 8 flathead engine.
    Feel free to get in touch with the "Auburn, Cord, Dusenberg" club, they will tell you the same thing, that particular engine is a stationary engine, and that wasn't the type that was used in automobiles.
    But you already know that!
    Even if the engine isn't stuck, there is no support for those engines, unless you have deep pockets and a connection to a very experienced machine shop, and even then, they will just smile and say to you,
    "Good Luck" on your journey to find viable parts etc, etc, etc!
    But hey, don't get discouraged, it will be interesting to see what you actually do with it or what you adapt it to!
    Thanks from Dennis.
    tractorguy likes this.
