M/C plumbing?
Discussion in 'The Hokey Ass Message Board' started by Slantback, May 16, 2010.
  1. Slantback
    Slantback
    :confused: Plumbing the brakes on my 37. Disc/drum with a 8" booster and corvette style master. Both resevoirs on the master are the same size, does it matter which one goes to the front or rear?
    Thanks.
  2. gimpyshotrods
    gimpyshotrods
    If they are truly the same size, then no, it does not matter. You will likely want to put a manual proportioning valve in the rear line, though, or you may be having a problem with the rear locking up. Wheel cylinders require a lot less fluid volume than a caliper.
  3. Slantback
    Slantback
    Thanks, I am putting an adjustable valve in the rear line.
