Projects M/F-ing HOT RODS, '32 3W build for a HAMB member!
Discussion in 'The Hokey Ass Message Board' started by ELpolacko, Aug 12, 2011.
  1. 3wLarry
    3wLarry
    from Owasso, Ok
    B1gDaddy, my comment of loving the smell of money refers to my love of high quality craftsmanship...which equates to large dollars spent in fabrication.
    Also, don't let anyone tell you what engine/****** combo to use. When I built my traditional 3w, I used a hydraulic roller cammed 327/Richmond T-10/Winters QC combo because I wanted to drive the piss outta my coupe...and I did.
    love your build...
    kidcampbell71 likes this.
  2. general gow
    general gow
    MODERATOR
    wabi-sabi...
  3. B1gDaddy
    B1gDaddy
    from aladambama
    thanks Mr. Roller. you guys set the bar pretty high!
  4. KICKSY
    KICKSY
    Love this build thread so far, nice work.
    Well done.
    Dave.:)
  5. ELpolacko
    ELpolacko
    After some measuring and a few trial fits, I have the front end of each X drawn, welded and attached to the rear half permanently. Installation went pretty easy and now working on figuring out the brake and clutch situation before I get too far. Looks like I'm going to need a relief notch for the clutch pedal to swing into.
  6. Jim Dieter
    Jim Dieter
    from Joliet
    Love it.. No boxing, all strength from the X, clean as hell... but looks like it belongs there. This makes a compulsive overbuilder like me rethink a few things.
    Thank you for the updates.
  7. flatoz
    flatoz
    Really enjoying the ch***is build up, the drama can go away though.
    keep at it ( posting that is elpolacko ) as theres plenty here who are keeping an eye on this.
  8. chopt top kid
    chopt top kid
    Now that's what I'm talkin' 'bout!!!
  9. ELpolacko
    ELpolacko
    Working on the pedals right now, taking pictures as I go.
    Reworking a stock '39 setup to work.
  10. Dynaflash_8
    Dynaflash_8
    from Auburn WA
    this is exactly how i feel
  11. Tinman
    Tinman
    from Orange, CA
    Love it when you bring something for show and tell, Steve. Amazing work on the crossmember!
    As Little Bill's wife says in Boogie Nights, "Don't stop big stud!" :D
  12. Mart
    Mart
    Wow! Just found this thread. Rudy did a great job on the body, Steve's doing a great job on the frame. Steve is a professional, this is what he does for a living. He takes the time out to show people how he does this stuff. Doesn't have to, he just does. The knowledge shared here is precious.
    And still some want to detract from the whole thing.
    Steve, loving the build, loving the how to video, and completely blown away by the animated image of the x member rear section.
    Hoping to be over your way next year, I'll be knocking on your door for definite.
    Mart.
  13. grovedawg
    grovedawg
    from Heber, UT
    Mine too!
    El P, thanks for your previous help with several questions I had about my Mustang II. I love this build and that you're building YOUR car the way YOU want. Keep it coming!
  14. ELpolacko
    ELpolacko
    First off, click and play the video.
    Ok, here we are with the music going, imagine the heat of a mid-August Phoenix summer and you wearing thick leather gloves and wielding an Oxy/Acetylene torch with a rosebud tip.
    The X is nearly done save for some bracing and final welding. You could see from the previous shots that the very front of the of the legs did not have the attachment plates tacked in. I drew up and cut those from 1/4" plate, drilled the holes and tacked them in place to cement the X and then could move on to my next issue... the brake and clutch system.
    I new that the clutch arm was going to give me some fits and because of the toe board location it would cut through my newly created front leg of the X. But I wanted to sort out a few things with the '39 clutch pedals first and then take care of the swing travel needed.
    I dis***embled the brake bracket and arms then heated up the clutch arm close to the pivot boss and straightened out some wiggles it had. These parts had been abused at some time and needed some tlc to get everything sorted out. I missed the first shots of squaring up the arm to get the pedal inside the cowl and missing the frame, but as you can see the arc was off. With some careful heating and a bit of manipulation, I got the arc correct so it will swing through a smaller hole in the floor.
    Back in place you can see how it hits the X and is now a bit too close to the brake. I changed the brake pedal a bit also so that it hits the toe board square and just looks better.
    I still need to adjust the arc a bit but it's close now. But the bigger issue is the pedal placement. I could lengthen the arm, instead I chose to change the end where the pedal attaches. I drew up a new arm end and cut it from 1/2" steel. Drilled and tapped a 1/4" pipe thread for the pedal to screw into. Sliced off the extra bits and TIG welded the end on and shaped it with a rat tail file to look a bit more correct.
    Now it looks proper. Heights and spacing are good and nothing hits.
  15. ELpolacko
    ELpolacko
    Nothing significant with the vid, I just dig it.
    Now that I have the pedals in place where I want them, I need to make room for the clutch to swing into. I brought out my Mythbusters blue paper and silver pencil and sketched up a few different ideas and came up with a loop to the back out of 1/2" plate and to cut out the crossmember. I had to diss***emble the entire system to do this, but I needed to weld up the front attachment plates as well.
    Here is the photo progression, sorry, no blue paper pictures.
    HotrodRon stopped by and took pictures of my balding head while welding
    And while the X was all apart, I welded and finished the other side too. Time to re***emble the whole thing again. It goes together pretty easy in spite of the 36 bolts currently holding it all together.
    That's it for this week, the rear suspension is up next!
  16. need louvers ?
    need louvers ?
    Imagine? ****! I just walked back out to look at the temp in the shop... Yep, We got temp! 112 degrees inside... 'Bout 55% humidity too! I pity you and your late work schedule around there! Lookin' good as usual! How about Pete's tomorrow?
  17. Jeem
    Jeem
    Alliance Vendor
    Impressive clip Steve! I enjoyed this.
    Oh yeah....good fab too. haha
  18. ELpolacko
    ELpolacko
    Pete's? Sounds good to me.
    Stan is the man!
  19. B1gDaddy
    B1gDaddy
    from aladambama
    Ok,
    Heat has obviously taken over. Apply Bud Light liberally and call me in the morning !!
  20. slammed
    slammed
    Lordy-B-freakin-Gordy this latest round of effort has my head spinning. You just flattened the nay sayers like a Mack truck with your work!
  21. Mr48chev
    Great answer to some of these low post mouth breathers who don't even own a real rod but want to knock a top notch build because they think it will up their creds as a "traditional car guy" garage full of Mustangs or no.
    At this moment we have a Hamber stuck on the other side of Missouri from the Hamb Drags trying like hell to find a water pump for a 401 Buick. A lot cooler engine than a 327 Chevy in some guys books but being stuck half way between home and the event you have been looking forward to for the last year really ****s when you can't get a new part except possibly by UPS red label in the morning and then turn around and go home because you missed the event.
    All that bs aside, this is one hell of a build with some really nifty pieces being designed. I think I may just have to get in line for one of those X member setups when they get perfected and if they come available. I'll be following this build to the end.
  22. ELpolacko
    ELpolacko
    I saw the breakdown earlier this morning and thought nearly the same thing.
    I've been shaking uncontrollably from lack of windshield time in my truck, and right now I should be stealing Shiner Bocks from my Texas friends in the host hotel parking lot. Been cruising the HAMB looking for the offbeat commentary from those attending in an attempt to cure the craving.
    At least I covered in hot rod dirt.
  23. daddio211
    daddio211
    Ha ha ha... quote of the day!
  24. ElP would not be caught dead in bud light but shiner bock is the drink of choice for him or fruity tiki drinks. The pictures do not do the frame justice you have to see it in person. B1gDaddy you are going to have one bad *** car. Like needlouvers said earlier we are gong to get along just fine when you come into town and we take you for good Mexican food and drinks to celebrate your new car.
    Those videos are priceless so bad ***.
  25. Slick Willy
    Slick Willy
    Thanks for displaying the pedal setup! WAAAYYY beyond what i did!!
  26. hotrd32
    hotrd32
    from WA
    Pedal set up is ***s.............nice job!
  27. A Rodder
    A Rodder
    INSPIRATION to do it the best you can
  28. THE-SYNDICATE
    THE-SYNDICATE
    YES!!!!!! ****'n Cl***ic....
    Seriously... This is some ultra *****in Work! That ch***is table is beyond cool! Keep it up and thanks for sharing all this groovy ****!
    ~Robert M.
  29. Uncle Bob
    Uncle Bob
    from Salado, Tx
    A '32 3w
    A traditional style SBC
    Tutorial vids
    Martin Denny AND Stan Kenton
    Whiner slap downs
    Talented craftsmanship of the first order
    And this vacuous post just to subscribe
    A thread with everything including promises of more, thanks Steve.
  30. Polaco I am so deeply offended by that car. I can't believe you of all people would post a gennie traditional build on this board. :rolleyes:
    Neat build my friend, keep it tight.
