Hot Rods M/T FIRST GENERATION SBC VALVE COVERS
Discussion in 'The Hokey Ass Message Board' started by scrotilson, Oct 3, 2020.
  1. scrotilson
    scrotilson
    Do any of Y'All out there have a picture of what I believe to be M/T's first gen. SBC VCs? They will have the 'THOMPSON' embossed in the center of the cover.
    Some years back, Kiwi Kev posted a page from an 1964 Thompson Speed Equipment catalog, that had what amounted to a drawing of those covers. I'd really like to see a photograph of the actual real deal valve covers.
    If you have one, please email it to: doug100@comcast.net
    Thanks guys,
    Doug Pratt
  2. Deuces
    Deuces
    Oh, heck!... Post a picture on here if anybody has one.. :)
  3. lumpy 63
    lumpy 63
    I have a couple of early MTs the one's that only say MT without the circles for breather cut outs but have never seen any that said THOMPSON , I have liked these covers forever and look for them at swap meets...If someone has pics post em up:D
  4. @scrotilson
    Here you go. Were mine but sold a while ago
    swade41, UNSHINED 2, bowie and 5 others like this.
  5. lumpy 63
    lumpy 63
    Wow! and they appear to be straight hole too, I figured they would all be stagger hole.
    loudbang and Deuces like this.
  6. scrotilson
    scrotilson
    Howdy, Thank you so much for that picture..........truly appreciated !!
    Doug
    loudbang, kadillackid and Deuces like this.
  7. scrotilson
    scrotilson
    From the 'For What It's Worth' Dept.: I have an ad in Parts Wanted classifieds. I'm looking for some different pairs of Rare SBC covers, this style THOMPSON's among them. The beginning of the ad title reads: PAYING THE PAYING BIG BUCKS..............
    Thanks Again
    Doug
  8. scrotilson
    scrotilson
    If this style was indeed the 1st generation M/T vcs, then they probably were 'staggered' hole initially. As you know, GM changed the head on the 283 around the middle/end of '58. Then came the 'straight' hole. As I mentioned previously, I've seen M/T catalogs as late as '64, with this 'THOMPSON' vc in it.
  9. Fordors
    Fordors
    Mickey might have produced that valve cover with staggered holes but I think he didn’t go into manufacturing speed equipment until 1960 or so.
    swade41, bowie and Deuces like this.
  10. Ok,
    I have found no evidence that he ever made a staggered SBC Thompson valve cover. But that doesn't prove anything because I've Seen many one off and or low production parts never in any Mickey Thompson catalog. I can however post what was advertised in catalogs.
    1) 1961 very first catalog
    Only valve cover listed is Pontiac
    2) 1962 second edition
    Still only Pontiac
    3) 1963 third edition
    First listing for Chevy is only one cover for 283 which would only be straight across bolt pattern in Mag or Aluminum from the picture
    1964 still shows only one cover for 283-327
    egads, loudbang, kadillackid and 4 others like this.
  11. B.SUTTON
    B.SUTTON
    from Peoria, IL
    D76B3C04-512E-49F3-BC7F-BE99BBFCA1D7.jpeg 0DD7A9A4-C57C-47F7-88E0-268BC7053CD3.jpeg
    I have a set of these early M/T logo Chevy covers without knockouts for breather/pcv. As you can see by the photo of the underside, these were either tooled up for either staggered or straight pattern Chevy heads, or there was a design change sometime in production. Perhaps the Thompson logo covers were similar?
    loudbang, lumpy 63 and Deuces like this.
  12. 1968 shows staggered and I have a set just like the above ones from B.SUTTON
    I think this one is from 1964
    Just Gary, egads, loudbang and 2 others like this.
  13. Here's those staggered ones that some imbecile drilled a pcv hole into, you can see the dual pattern and note the hold down groove is twice as wide as a standard M/T.
  14. I know they later made staggered in die-cast the original post is about the original Thompson cover. The first covers were sand castings. I believe these came after the Thompson covers
    Then the M/T sand cast with no holes or engraving pad
    20201007_200150.jpg someday I will try to fix this one.
    Then came the engraving pad
    20201007_200012.jpg 20201007_200210.jpg notice this is sand cast and the engraving pad is much thinner than the mass produced die-cast later covers. It only goes up to the third fin and two fins above the M/T
    Just Gary, egads, bowie and 4 others like this.
  15. continentaljohn
    continentaljohn
