Technical M62 and M90 superchargers
Discussion in 'Traditional Hot Rods' started by Gocango, Oct 1, 2016.
  1. Gocango
    Gocango
    Are the eaton m62 and m90 superchargers capable of being adapted to draw through carb use? Also what are the practical limits of hp and cid for them. Im eyeballing one for a AMC 252 I6. would like to stay carburated and I have machining and some fabrication skills.
  2. gimpyshotrods
    gimpyshotrods
    @blowby, ain't you running one of these?
  3. firingorder1
    firingorder1
    I can't think of a reason as to why not. Apart from possibly the bearing not being sealed I don't think there is any reason, I've been told that the Eaton is a very efficient blower but generates a good bit of heat. Draw through makes an inter cooler impossible but I suppose the amount of heat generated would depend on how much boost you want. I'm running an Aisin AMR300 on my LSR sidecar. It originally blew only air. I'm running it as a draw through. No problems in that respect.
    LOU WELLS likes this.
  4. Rusty O'Toole
    Rusty O'Toole
    The only objection I can think of, is that gasoline might damage any seals on the rotors or bearings. I know nothing about their design or construction, this purely speculative.
  5. blowby
    blowby
    from Nicasio Ca
    Yep, on a V8-60. Only have a couple hundred miles on it, I put it on my old tired engine before replacing it this year. On the road again now. As I recall the bearings had seals but I can't be positive. All good so far. I read a couple threads about their successful use, mostly on inlines, before I started. Probably too small for larger V8s. Also there is another thread where a guy built an intercooler that goes underneath.
    Asphalt Demon likes this.
  6. Rand Man
    Rand Man
    Blowby, would you post more pics of your setup? I can't really tell how the carbs are mounted. A duct would have to come from behind, up and over.
  7. gimpyshotrods
    gimpyshotrods
    IIRC, he machined his own inlets on the top, and closed the original inlet at the back.
  8. blowby
    blowby
    from Nicasio Ca
    The front carb does go through the top, rear through a manifold bolted to the stock rear inlet. I did a thread on it but I can't find it.
  9. gimpyshotrods
    gimpyshotrods
    Weird. I cannot find it either. I remember it.
  10. 73RR
    73RR
  11. LostBoy
    LostBoy
    Yeah I was going to say, intercooling is 100% possible with a roots style blower.
  12. BOBCRMAN
    BOBCRMAN
    from Holly
    GM engineers say the seals in the Eaton superchargers are not compatible with fuels. One of my customers was on the development team for supercharged GM engines. He actually perfected the production 3.8 turbocharged engine/heads in his home shop.
    LostBoy likes this.
