machine shop failed me. advice?
Discussion in 'The Hokey Ass Message Board' started by Chryco36, Aug 31, 2012.
  1. Gets sillier every time I here this argument
  2. temper_mental
    temper_mental
    from Texas
    That dash is jacked up bad. I asked myself would I charge myself my own shop rate to fix it? (65 dollars an hour) $390 in labor. Hell no. So if I fixed it, I would be wasting my time.
    Sometimes you have to live and learn. I would cut my losses sell it at a swap meet. I look at it stricktly black and white.
  3. bobss396
    bobss396
    IMHO, that would be a pretty big diameter pipe to get that gentle of a radius piece out of it. The dash may be saved, in the hands of a real good craftsman and welder.. not cheap either.
    Bob
  4. ClarkH
    ClarkH
    I'm wondering how a professional could think this was acceptable work. Two possibilities: 1) he was drunk, 2) he was under the impression esthetics didn't matter, like maybe they were lightening holes that would be out of sight.
  5. the shadow
    the shadow
    Wow, stevie wonder could see they're way off!!!!
  6. I agree. It can be saved with sheet metal, lots of time and skill. I don't think hacking up exhaust tubing would help. I think your two choices are another dash or lots of metal work.
  7. RC Kid
    RC Kid
    from Alabama
    So few people and businesses take pride in their work anymore. It's just shameful. Good luck with the repairs
  8. If were to fix that,,,,
    First there would have to be none available
    Or just because I wanted the practice.
    I would form the front section from end to end and weld in one patch.
    I think your pipe idea is not going to give you anything comparable to what you started with.
    But that may be exactly what you're after , different.
  9. I would take a piece of panel plastic, heat is and mold it over the section where the holes are, then glue on padded material to match the rest of the interior, padded dash, less work....no welding.
  10. wizzard23
    wizzard23
    Stevie Nix, what you call Stevie Wonder after he tries to shave!
  11. banginona40
    banginona40
    Patch the holes and move on.
  12. storm king
    storm king
    I'll do something really off the wall here and actually respond to the quesiton you asked. Have you simply considered cutting that whole area out, taking a panel flanger and putting a joggle around the perifery of the new opening, and tacking or spotting in a new piece? Using a lighter gauge of steel might allow you to get some of the contour in it, then fill and sand. Just a thought.
  13. Pffft!
    Silly rabbit, that would be called a "repair". What were you thinkin'? ;)
  14. kyvetteman
    kyvetteman
    We all tend to use the term "machine shop" loosely in reference to those that do our engine work but there are other types of machine shops that don't know diddly about engine blocks or heads but do great work on other stuff.
    There was an awesome one in my hometown of Paris, KY that was family owned and had been there for 3-4 generations. Those guys were true craftsmen but there's not much call for that kind of facility nowadays, but I digress.
    Hope you get your dash squared away in any case...
  15. banginona40
    banginona40
    I like that idea too!
  16. How about a padded dash? Piece of foam,piece of vinyl,problem solved.
  17. Chryco36
    Chryco36
    Just ****s, I bought pearl white paint and metal flake for it. The rest of the interior came out nice. I just figured that the pipe idea would be easy and look decent. Thank you for the advice though guys! I am seeking a new dash
  18. 41fastback
    41fastback
    A. Forget the hole idea.
    B. I would never go looking for a new dash. I don't get it.
    C. Take the time (when you get your tools back) to make plugs (holesaw or otherwise) and weld them in. It will take a few hours. Bondo to suit.
    D. Paint.
  19. Chryco36
    Chryco36
    Yes with the hole idea! lol I found someone selling a dash for 100 bones im good
  20. Chryco36
    Chryco36
    Got my garage back and did it myself.
  21. Cl***ic. LFMAO :D:D:D
  22. A Rodder
    A Rodder
  23. rottenleonard
    rottenleonard
    Pat yourself on the back for not backing down on your idea with all the ribbing you been getting on this thread. The holes don't look bad at all, and cookie cutter cars get boring to look at.
    Lightening holes are traditional!
  24. Chryco36
    Chryco36
