Technical Machine shop question
Discussion in 'The Hokey Ass Message Board' started by MGK, Mar 23, 2017.
  1. SEAAIRE354
    SEAAIRE354
    The prices on the list you provided seem fair. I was charging more than that years ago but I live in a very expensive part of the country. If I read it correctly they already rough bored the block to .060 so finish honing isn't an option it needs to be completed. I agree with every ones opinion the crate motors are good these days. Back in the target master days it was a gamble. Not anymore.
    The engine building book is a must. And if you go with the 283 and there the original heads the exhaust seats need to be Replaced with hardened seats as other people have mentioned. Also if your going to run a flat tapper cam do you homework on proper brake in procedure and proper oil with sink or additives. Hope this helps and good luck.
  2. saltflats
    saltflats
    from Missouri
    He did say it was his first...we all started there.
    You got to learn.
    My dad started me with some small engine repair books.
  3. saltflats
    saltflats
    from Missouri
    Okay I went back and re read the up date and it sounds like you are parts shopping now.
  4. henryj1951
    henryj1951
    from USA
  5. henryj1951
    henryj1951
    from USA
    what has been done.
    I owe them $432.34 as of today.... PAY THEM and
    re-group .... start a LIST of what is next, and next, so on and so on.
    gas & guns and SEAAIRE354 like this.
  6. SEAAIRE354
    SEAAIRE354
    henryj1951 likes this.
  7. steinauge
    steinauge
    from 1960
    I just(last year) had a 283 block tanked,bored and honed .060,decked .025,cam bearings,freeze plugs that I supplied installed.Total was a flat 500 bucks.I have used this guy for years and he does good work.I would agree that you need to go pay what you owe and pick up your parts.Comp products is an excellent source for 283 parts ,so is e gay.
  8. Dyce
    Dyce
    A rebuild kit for a 283 is more than double the price of a 350. The prices for the machine work seen fair. You will need the pistons pressed off and on as well. I haven't seen prices for the heads yet. I am sure they added a good amount to the total.
  9. jimmy six
    jimmy six
    Boring it to 060" was crazy. My machinist would have power honed it to .040" and been done. He has our racing Dart block we are moving to 4.165 from 4.155 and its all hone. I may have used a glaze breaker and carbon ball hone on your engine and went with the .030". A few thousandths taper is easily lived with, and put in a set of Total Seal rings with some stock replacement Pistons. I agree with Compe***ion Products for a supplier also CNC in South Dakota.
    Some of you may think this is "on the cheap" but in reality it is not. Cleaning and checking out your parts by using a reputable shop is fine. But with a few basic tools and borrowed mics can tell you a lot especially if it was a running engine with no known problems. If the crank mics good polishing with some 800 followed by crocus cloth is all that's needed. Even without mics you can just buy the size of bearing after all its on the back of the bearing. In a stock engine I've never seen bad cam bearings ever. The best $$ will be spent on the heads with a good valve job, possible exhaust seat change and guides/seals. If more guys would just look what they have and use it, there is some pride in it.
    Yes I agree with some of these low HP GM crate engine but I would take it apart and clean it too. They leave a lot of **** in them too and they are Hecho in Mexico.
    Anyway good luck and remember to have fun. Oh yes I love the 283 and what's a 350? Nothing but a 283 bored an 1/8" and stroked .480".....
    olscrounger and henryj1951 like this.
  10. and do some good swap meet and CL shopping
    and raid your buddies garage and don't forget the local pic-a-part
    I paid $40 bucks for this intake (performer) at a swap and $45 for the 462s at a JY
    the alternator was a freebie + the $25 rebuild kit and 1 wire conv.
    pulleys were $10 JY items and the brackets were $70 internet items
    $15 pic-a-part carb and $30 kit
    the valve covers were CL scores that were free after selling the **** that came with them+ the wrinkle paint and HF polishing kit
    headers were $50 on CL + paint and some free wrap
    the short block was a trade for a little labor.
    so far, this thing runs just like you see it for less than $1300
  11. plym49
    plym49
    from Earth
    THIS! It's not as much if the machine shop's quoted prices are in line, it is whether you need to have that work done at all.
    Do you really need the crank cut? Block decked? Heads magnafluxed?
    Don't get seduced by the 'you have to' brigade.
    gas & guns likes this.
  12. dan griffin
    dan griffin
    If you want to spend some real money try building a early Olds. You can buy a lot of sbc parts for the price of a Olds gasket set not to mention the fact you can go down to the drug store and buy sbc parts. Wastedchildhood
  13. saltflats
    saltflats
    from Missouri
    ^^^or a 409
    warbird1 and henryj1951 like this.
  14. henryj1951
    henryj1951
    from USA
    ^^ or find a head gasket for the 161ci (6)cyl Henry J
    osage orange, warbird1 and saltflats like this.
  15. ^^^^^early hemi^^^^^^
    may have to take out a mortgage to finish mine
  16. You need to decide if you want to get the 32 on the road, or build an engine for the experience. If getting iy on the road, buy a crate.....least expensive way to go. Then build the 283 as your bank account allows, then swap and sell the 350. (Sell while it is still in the car so buyer can see/feel it run). There is great satisfaction in doing as much as you can, but the economics of individual rebuild vs crate say do the crate. Been there several times and my son is a machinist doing work on vintage race cars, but the engine for my current build, 59 Corvette street mod, will be a crate....all a matter of time and dollars. Good luck, a hard decision.
    Sent from my SM-G900V using The H.A.M.B. mobile app
  17. bobss396
    bobss396
    My block was decked, I also omitted the balancing above in what I paid. Past a standard rebuild service, it adds up quickly. Most shops have a standard rebuild price, you dis***emble, they clean, inspect, change the usual parts, cam bearings, freeze plugs. I find that their ***embly prices are often a bargain, I went for it as I was pressed for time. Some will sell you the bearings and rings at their cost or close to it.
    I had one local shop that was great to work with when I was racing stock cars, tragically the owner died between me seeing him on a Friday night and him not waking up on Saturday morning.
  18. 34 Plymouth Hemi
    34 Plymouth Hemi
    Prices seem fair based on machine work here, NY Metro area. I'd have him finish hone the block, and put in the cam bearings. if the budgets real tight clean the block and install the freeze out plugs yourself.
    There's a lot of satisfaction in ***embling your own engine. It's not usually going to be cheaper to build your own, but it's something you can say you did yourself
  19. Wallaby
    Wallaby
    Lots of stuff to think about.
    When the shop did it's inspection, did they hot tank the block? I have heard that ruins the cam bearings. Maybe that isn't the case, but it's a question you'll need to ask.
    I am currently running an early 327 that came with my project, and it runs great... but it has different motor mounts and no bolt holes in the fronts of the cylinder heads. If I want to add power steering or AC to the engine later, it will require some expensive and funny looking brackets to make it happen. The cost of the brackets alone is probably more than the cost of a used 350.
    Look far ahead and figure out what your plans are. You may find that using the engine you already own is the more expensive option.
  20. gas & guns
    gas & guns
    Rebuild kit from Summit is around $350. Your basic kit 60 over cast flat top pistons. Stock oil pump, freeze plugs, gaskets, rings, cam bearings, crank and rods bearings.
    Heck, at the prices they quoted, I'd be willing to learn how to ***emble one myself.
    Buy David Rizards book, Rebuilding The Small Block Chevy.
    After reading it, you may decide to build it yourself. At the very least you would know more about what goes into a rebuild.
    After reading his book some 25 plus yrs ago, I even hung my own pistons using a propane torch to heat the small end of the rods.
  21. lowlid30
    lowlid30
    As an engine builder of 40 yrs experience & a Hot Rodder as well .. I'd like to comment on your additional items being considered. You've obviously chosen an early 283 Chevrolet as your choice of a Vintage engine to go with your '32 5W Coupe .... So disregard your crate engine options as it does not go with the period correctness of your Coupe . .... The cylinders have been ' rough bored ' so you need to have them final honed to size as per clearance to the new pistons . An extra option is to have it ' Torque plate' honed , this would be an additional cost . But not a necessity. The old Cam bearings ' must' be removed to clean the block correctly , as boring material from the cylinders gets into all the oil galleries ! Including getting behind the ' 58 yr old ' cam bearings. Once again 58 yr old Freeze plugs were not made of Br*** and will be very prone to leaking . Causing problems at any time .... the Plugs in the rear of your block being the hardest to get too with your engine & trans installed . These items are a necessity & not an option !! And enjoy years of trouble free cruising with your club & buddies ..
    anthony myrick and SEAAIRE354 like this.
  22. DDDenny
    Spell check.
    David Vizard.
    Great book, every first build should include this.
  23. henryj1951
    henryj1951
    from USA
    ^ I know NOTHING (sergeant schultz )
    wicarnut likes this.
  24. gas & guns
    gas & guns
    Can't believe I muffed that up. I would have sent him to the wrong library.
  25. Marty Strode
    Marty Strode
    When I had my 283 machined, a lot of the money for labor and parts was spent on the cylinder heads, but I just had to have "Power-Pack" heads !
  26. Baldies
    Baldies
    New rings and a valve job can make all the difference.
  27. Engine man
    Engine man
    from Wisconsin
    Less than $275 on Amazon for either .040 or .060 283 kit including pistons, rings, bearings, timing set, oil pump and gasket set.
    You most likely just need a dependable decent running engine. The car is light, you aren't likely to put thousands of miles on it and you won't run a lot of rpm. The bore was .030 over so it has been rebuilt and how long ago was it?
  28. BradinNC
    BradinNC
  29. henryj1951
    henryj1951
    from USA
    ^ Very good place , I know the owner.
  30. sdcoupe33
    sdcoupe33
    What are your expectations from this motor? If you spread the cost out over time you can build it the way you want it without limitations imposed by a short time frame and limited funds. Throw a junker 350 in there for now if you need to get it on the road while you rebuild your motor.
