Machining a French flathead
Discussion in 'The Hokey Ass Message Board' started by DjNeil, Sep 18, 2013.
  1. DjNeil
    DjNeil
    Hi
    I've just been offered a 255 French military flathead to stick in my 51 Mercury
    I'm thinking of taking it to a machine shop to get the bellhousing milled off and the block tapped to accept a late model 3 speed 49-51 overdrive trans and bellhousing. Has anyone on here done this or similar and has any tips
    Thanks
    neil
  2. fenderless
    fenderless
    from Norway
    Buy an adapter instead:) Or just make one.:)
    K
    Taildragger&fenderless
  3. Dale Fairfax
    Dale Fairfax
    Doesn't the block have the standard '32-'48 Ford bell housing? If it does. all you need is the '49 Merc transmission. It still has the old style bell on the front.
  4. RichFox
    RichFox
    That is what I was going to say. Why would you do that so that you can bolt on the adapter Ford used in 49?
  5. 38 coupe
    38 coupe
    from Texas
    Dale Fairfax is 100% correct. The stock 49-early 51 Mercury transmission bolts right onto the cast on bell housing. Comes in overdrive too.
  6. mike hohnstein
    mike hohnstein
    from wisconsin
  7. Ddooce
    Ddooce
    from Memphis Tn
    I am sure he is asking about machining as he is in FRANCE where 39 Mercury trans are about as common as a Simca Aronde trans in Texas!
  8. RichFox
    RichFox
    He said he wanted to bolt a 49-51 trans to it.
  9. I just went and looked at both me early and late motors. Even after machining I don't believe you can get the surface needed to tap holes for the late bell housing on the early block. Spacing is critical to get Flywheel and starter in the correct place. I've done lot of Odd things to old iron but seeing what I have on hand I think I'd just plane not try it. Like mentioned a 49/50 Merc overdrive or a T-5 would be my choice. They have been done and no machine work to them.
    The Wizzard
  10. Jalopy Joker
    Jalopy Joker
    do not mess with the block - there are a lot of impurities in the metal used. bolt on stuff sounds better.
  11. From the statement of doing the machine work it sounds like he's talking 49-51 Ford not Merc.
    The Wizzard
  12. 40FordGuy
    40FordGuy
    What they all said ! That 51 Merc OD trans is a bolt in. Same exact bolt pattern as the older Ford trans. It also has the 10 spline input shaft.
    4TTRUK
  13. DjNeil
    DjNeil
    That's the best news i've heard in a long time
    thanks
  14. Just to be real clear here. 1951 was a different unit and 51 Only. It is not what you want for the early Block. 1949-1950 and some real early 51's. They are what you want. They look just like the 1940-1948 Ford Car ******. 1951 Merc used what became the standard 4 bolt gear box case with a 1 year only Merc only bell housing and it only fits the last generation Flat Head blocks. You do not want that set up.
    The Wizzard
