Technical Machinists, what is the technical name for this?
Discussion in 'The Hokey Ass Message Board' started by Roothawg, Aug 4, 2022.
  1. AccurateMike
    AccurateMike
    The difference between a mill and a drill is pull. On a mill, depending on the direction of cut you are "conventional" or "climb" milling. The direction of the helix is pulling the tool out out of the holder during climb milling. A mill's tool holder uses a drawbar (long bolt) to hold the tool holder in the the spindle (like an R8). Drill presses (and lathe tail stocks) don't experience pull and use Morse taper holders (relying on friction only to hold the adapter in) and will pull out of the spindle if you climb mill. Sure, the spindle bearings in a mill are sized to account for more side load but, the real difference is the drawbar. Mike
  2. Rickybop
    Rickybop
    I love the smell of hot chips and oil in the morning.
    ekimneirbo and bobss396 like this.
  3. DDDenny
    I did too.............for the first twenty years!
  4. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    If I go more than 2 or 3 days without turning or milling something, I start to suffer withdrawal symptoms!
    bobss396 and seb fontana like this.
  5. gimpyshotrods
    gimpyshotrods
    I just re-patterned a set of wheels last night, boring for mag-shank lugs, and cutting flats for washers!
    I am resisting the urge to go to the shop today. The wife says that working 7-days is not healthy.
    Tickety Boo likes this.
  6. seb fontana
    seb fontana
    from ct
    I used to be that way. Surprised myself that once I retired (Toolmaker) I slowed down quite a bit.
  7. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    I just putz. I taught Auto Mechanics and related subjects. My Dad was a machinist and I always envied his abilities carving on steel.
    bobss396 likes this.
  8. I folded the business up in 2019, I had a 30 year run making parts at home. I've been making chips for $$ since 1981. I still barter work on my car for machine time with one shop. I do things like remove broken bolts and studs.
