Mack Truck Car Hauler Project
Discussion in 'The Hokey Ass Message Board' started by jim_ss409, Jan 24, 2010.
  1. junkyard junky
    junkyard junky
    I love those macks
  2. Drewstang
    Drewstang
    As a Fire Fighter I can honestly say I'm glad to see this piece get donated to such a nice project. Like someone else mentioned, after an aparatus is sold from a department its most likely to wind up in a field rusting away. Good progress so far and I can't wait to see the finished product.
  3. 56gasser
    56gasser
    from lower al.
  4. Johnny Gee
    Johnny Gee
    from Downey, Ca
  5. That's cool how you turned the firetruck bed into an art deco(?) style bed.
  6. As Ralph Cramden used to say..." How Sweet it is!!!!!!!!!! "
    Your project is only half done, and it's already a sucess... Now I love firetrucks, and B model Macks, This truck kicks ***, your project is really on the right track!!!!
  7. neonloverrob
    neonloverrob
    from newton, ks
  8. 29bowtie
    29bowtie
    Well done, that's a very interesting way to keep that "B model" alive and working. I've showed these pics to people at work, at our Mack Dealership, and it certainly gets a positive response from them all, especially the older guys, who are very fond of the "B Models".:D They are very impressed with the high quality build you are doing, thanks for sharing it with us.
  9. jim_ss409
    jim_ss409
    The visor is pretty simple but it took longer than you might expect to build it and get the brackets right. Nobody makes a metal visor for these trucks and none of the Fulton style visors seem wide enough.
    We used a flat piece of aluminum and bent it around a big piece of ABS pipe to get the ends to curve. Then we used some door edge trim to get the rolled edge look.
    Stainless would be more durable but it's harder to work with.
    We tried to come up with a more peaked, Peterbilt style visor but we just couldn't get it to look right when we mocked it up. The more rounded visor seemed to look the best from any angle.
    We had to modify the firewall quite a bit to make room for the heater-air conditioner etc. but we still needed a small doghouse so we welded in a stainless kitchen sink.
    Here it is covered with sound deadener.
    We weren't sure how we were going to carpet the doghouse so we made a removable fibergl*** doghouse cover. We did that by forming a sheet of acoustical lead over the doghouse then building it up with fibergl*** and body filler.
    Here's the lead sheet.
    Here we're fibergl***ing it.
    Here it's almost ready for paint.
    We converted the filler panels under the cab into storage boxes.
    There wasn't a lot of room for fuel tanks so we built some in order to get the maximum amount of capacity. They mount up under the front of the box.
    We used caps from the fire hoses for fillers.
    The plan is to do a wooden floor in the box but if we're running too low on time we may just use steel or aluminum checker plate. We have to have the truck ready by spring in time for the racing season. It's been going pretty good now that we've been getting one or two days a week to work on it.
    Here's a picture of the truck beside the race car. The car gets hauled in a 40' enclosed trailer. We're painting the truck to match the car.
    I'll continue to post progress pictures as we go along.
  10. bubba67
    bubba67
    from NJ
    That thing is BAD *** !!!!!!!!!!!!!!!!!!!!!!!!
  11. Looks fantastic!
  12. LowBlazin
    LowBlazin
    from Austin, TX
    its great to see this fire truck saved from probably sitting in a field someday.
  13. 201
    201
    Nice job on the B-model !!! Just some related truck facts- the tires on the back are called super singles or flotation tires and the only B model with factory power steering was the B-53 series. You should keep a 2-stick ****** in it just to keep the kids out.
  14. bigblockdude402
    bigblockdude402
    Amazing, I love it. Always wanted to do something along those lines in the 1-ton category with a Powerstroke or something. I know where there is a late 30's dodge fire truck that would make for a good haul rig like that. I'd put a Cat in it tho. j.k. Looks awesome. Subscribed!
  15. jim_ss409
    jim_ss409
    Jon, The tires are the new "super singles" that a lot of the highway trucks are using. One tire carries the same load as a set of dual regular tires. I think the size is 445-50R 22.5 They're lighter and ride a little better than duals but we mainly used them because we thought they looked cool.
    The trans is a 4 speed Allison automatic and I think we'll go ahead and use it for now but we recently acquired a newer 3,000 series six speed Allison with a lockup converter so that will be going in once we track down the necessary electronics.
    As for when this thing will be finished, I keep saying that if it was a car it would have been done by now. We started on it about a year ago. We have a firm deadline in mind. We for sure want to use it to go to the G***er meet at Thompson Ohio on the first weekend in June.
    Tailgater, We couldn't adapt the power steering from the bus because the Mack has a wider frame at the front so we're going to try it with the manual steering. It wasn't too bad to steer even with the heavy fire apparatus and larger Mack engine so I'm hoping it will be OK now that it's quite a bit lighter. It has a huge steering wheel and it must take about eight turns to go from lock to lock so it has plenty of gear reduction.
    If it's a problem we can add a hydraulic ***ist cylinder. We have some experience with them and they can work very well if they're set up properly.
    Here's a picture of the big steering wheel and Winston the bulldog checking out his new truck.
  16. Chevy Gasser
    Chevy Gasser
    NICE B MODEL! I used to own four at one time, years ago, would loved to have kept them but I didn't have time enough for my cars. You made a wise choice of the DT 466T with the Allison trans. The engine is relatively small, adequate power for a truck and trailer that size. Very dependable and quiet and economical enough to drive it all you want. I hope to see it in person some day. This truck jumped to the head of the line for my top 10 all time favorite B Models!
  17. OoltewahSpeedShop
    OoltewahSpeedShop
    Damn....
    I hate seeing stuff like this.... I have enough projects. Now I've gotta start looking for a Mack truck.
    I need one of those in black to pull my dirt car with. I won't sleep for weeks now.
    Thanks Alot! :D
    Kevin
  18. Frosty21
    Frosty21
    from KY
    Love these trucks. My dad had three when I was a kid, still have two. First one was a straight job, then a dump truck, and finnally a tractor when he sold it for parts. Another cab and ch***is we have sitting around rusting. The other one has a Millitary Boom and is pretty much a mess of cheap bondo and hydraulic lines that we start every couple of years. Nothing like the sound of the air starter on these things either.
  19. great looking truck and perfect mascot! ( winston)
  20. jim_ss409
    jim_ss409
    Thanks for all the comments.:D
    Someone was asking what year the truck was. It's a 1957 but they made the B models for quite a few years. I think they came out in the early 50's and ran through to about 65 or 66. I used to own one back in the early seventies and always wanted to get another one.
    Here's a few pictures of other B models.
    Here's one I recently saw in a HAMB thread
  21. Bama Jama
    Bama Jama
    I love that truck.My dad drove a B61 Mack with a duplex trans in it all over the eastern U.S. back around 1959 and I used to go on alot of trips with him. I think the B61 ran from '53-66.They didn't have all the regulations reguarding riders they do now. Bill
  22. Salty
    Salty
    from Florida
    Thats the epitome of cool!
    And by the way...thanks for the idea on the doghouse cover outta gl***....gonna have to steal that as I've been wondering what to do about my modified firewall/doghouse and how to make it look decent covered...
    Now where'd ya get the acoustical lead? that stuff will be magic for forms
  23. Thats a great picture of your mascot!!!!!! I noticed that the interior of this truck was painted red. I thought they were all painted green. at least all of the firetrucks I've ever seen had green inner paint.
  24. gafridge
    gafridge
    Wow,looks fantastic,I have always loved the b model Macks.It's going to look awesome towing the trailer.Keep posting pics as you progress,good luck with making the deadline. Stony
  25. TERPU
    TERPU
    That's outstanding. I love every bit of that. Thank you for sharing.
    Tim
  26. Hoptup Jalop
    Hoptup Jalop
  27. the power steering on a air brake bus is mounted to the back of the air compresso off the timming cover in the left side
    i think you can get a plate and berring and make a mount to put the pump in that mounting hole
    absoutly cool truck
  28. jim_ss409
    jim_ss409
    Yep, the pump's there but the problem is with the steering box itself. It's a different configuration and won't fit.
    We got a roll of it years ago for another job we were doing. I'm guessing it's about 22 gage thick, maybe a bit thinner than auto body sheet metal. I remember they called it acoustical lead and it is lead but it might have something else mixed in because it seems a little stiffer that straight lead.
    You have to keep in mind that lead is toxic when you're using it.
    Yeah, I thought all B model Macks had that green interior but I guess they painted some of the firetrucks red.
    Winston the Bulldog used to be at the shop quite a bit but he's got a problem with his back legs now so he's not there as often.
    If he's there I try to get him in the picture.
    Here he is "helping" on the 55 Chevy.
  29. You get my vote for BEST ongoing concept to build project
    on the HAMB :D
    FIRST CL*** from design to finish Jim ......
    Jim
  30. A.P. Photography
    A.P. Photography
    This is going to be a bad *** hauler. Can't wait to see it done.
