I am working on a '31 Model truck. The fenders are in poor shape. I have a chance to buy some '34 truck fenders, will they fit? I am also mounting a '32 Grille, will these work together. Help! Ron
it depends on weather its a wide bed or a standard bed pickup wide bed are hard to find and bring a good buck standard bed are the same as coupe or roadster i think tk
The 34 fenders will not work. You need 30-31 fenders or you could run 28-29 fenders if you use the aprons and running boards that go with them. Some people like how the 28-29 front fenders curve around the tire better. Rears fenders are the same as coupe or roadster unless it is a late 31 wide box, in which the fenders are unique. A 32 grille shell will work with any of these.
The frames are different from model A to '34 and the front fenders won't fit, they mount to the frame. The rear fenders are also different. While they look alike a Model A and a '32-34 are very different. The 32 grille shell will fit, and has been done a lot. Red
