Projects Magnesium 12 spokes - cleaning of dirt and oil - not polishing, not blasting
Discussion in 'Traditional Hot Rods' started by 345, Oct 30, 2017.
  1. 345
    345
    from Michigan
    So I picked up these really nice 12 spoke Americans on the weekend. Before I get a lot of folks posting links to some of the great techs and older posts on here about restoring magnesium wheels (which I have read through) let me be clear that I just want to clean them up and get the grease out without damaging the magnesium or removing the patina.
    Thanks for help :)
  2. 345
    345
    from Michigan
  3. 345
    345
    from Michigan
  4. oldolds
    oldolds
    I would take them to the car wash and pressure wash them first. That will probably be the best way to see what you have.
  5. alchemy
    alchemy
    Spray them with brake cleaner. It won't remove any of the corrosion, and the only color change will be the dirt that's gone.
  6. elgringo71 likes this.
  7. I don't know about magnesium wheels. I have used spray Gunk on aluminum wheels to get tough brake dust off. It has worked well for me. Just don't do it on wheels that are still warm...it will stain them. Gene.
    ghornbostel likes this.
  8. dumprat
    dumprat
    from b.c.
    Don't use chemicals on mag! Gunk wheel cleaner will make them react! As will some chlorinated solvent brake cleaner.
    Wash them with varsol and a plastic brush. I worked in a helicopter overhaul shop for six years. Mag is really reactive to even common chemicals.
  9. deathrowdave
    deathrowdave
    from NKy
    Let your dog pee on them for 2 weeks they will be ready ! I ran mags for years , trying to keep them polished , caused me to get gray hair and then loose it !
    mgtstumpy, mad mikey and stillrunners like this.
  10. bowie
    bowie
    Over 4 decades, I've mostly used WD40 to maintain a cool shade of gray. Haven't noticed any detrimental effects, yet.
  11. Deuces
    Deuces
    Hot water will turn them dark grey.....
    We wash mag parts at work with dawn dish soap and cold water... Then rinse with cold water...;)
  12. 345
    345
    from Michigan
    Thanks everyone “dawn” is the winner. I’ll post when they are clean.
  13. when I pick up mag wheels sometimes the patina does not match wheel to wheel or has stains. I glass bead them clean then let them age to perfection. wd-40 gives them a dark grey uniform look without any white corrosion. I prefer the look of polished mag. staying on top of them is key.
    j-jock likes this.
  14. chevy57dude
    chevy57dude
    1. Maryland HAMBers
    X 2 on Bowie's WD-40, once thy're clean. Keeps my spokes and centers the right shade of grey.
    john walker, bowie and Ron Funkhouser like this.
  15. No personal experience, but consider soda blasting.
  16. dumprat
    dumprat
    from b.c.
    Heli parts are blasted with recycled plastic.
  17. DDDenny
    You might PM harryhotrod and see what he did, looks killer.
    Jebo and mad mikey like this.
  18. 345
    345
    from Michigan
    Sure does look the goods! Thanks for the tips everyone!
  19. 345
    345
    from Michigan
    Does anyone have the bearing numbers for these 15x3-1/2 to suit an early Ford spindle?
  20. call pete and jakes. they have the ford bearings in stock.
  21. Fordors
    Fordors
    Numbers from my notes-
    Early Ford/Timken
    Inner cone B 1201/15118 Inner cup B1202/15250X
    Outer cone B1216/09074 Outer cup B1217/09196
    Be wary of bearings listed or advertised as replacement for Timken, they could be off-shore mediocre quality.
    mad mikey likes this.
  22. 345
    345
    from Michigan
    Great info and advice, thanks guys!
  23. harryhotrod
    harryhotrod
    22C968C1-B011-44D8-A884-0E19B53FB17E.jpeg BFA69580-3021-4B07-B508-D0C03FE94E09.jpeg Hi 345
    As my front and rears were different colours with various stains etc etc, I media blasted all four (walnut shells) to get a uniform light grey, then used a product call ROCAL, it is a zinc based anti seize compound, wipe it on and rub it back off, they look a nice dark grey and the product stops oxidation when then get wet or damp........spent years trying to keep on top of them when polished.........never again
    Bear claws got the same treatment
    345 and mad mikey like this.
  24. DDDenny
    And "bear paws" too!:cool:
    345 likes this.
  25. maneri
    maneri
    from ohio
    looks like he's got good taste to me (with extras too)
  26. harryhotrod
    harryhotrod
    00AA46C3-A098-4DDF-9F29-F710251D6553.jpeg Your coupe looks great with the paws and 12 spokes Maneri
    Could only find this photo of the paws on my roadster........must have been a while back as they were polished then.......
  27. There is just something about polished magnesium. I swear at them everytime i have to clean them up. I swear by them when im done. 20170713_192550.jpg 20170713_192601.jpg
    mgtstumpy, 345, chevy57dude and 3 others like this.
  28. 345
    345
    from Michigan
    That bright white high light of magnesium is absolutely stunning. Pretty awesome too that the low maintenance approach can also be spectacular. I like the light duty bead blasting to even out the base tone. Will give that a crack I think :)
  29. 1934coupe
    1934coupe
  30. make sure its glass beading. there is a difference. sand or worse yet oxide will produce a very rough finish.
