Text (no calls) (780) 486-2488 or email stevephillips@telus.net. All prices plus shipping or you are free to pick up locally - parts are at my shop just south of Edmonton, Alberta, Canada. SOLD!!! MAGNESIUM Halibrand V8. For those who claim Halibrand never made magnesium rear covers, this one is proof that they did - both the case and the finned rear cover are mag. Standard 3.78 r&p (I'm removing the spool - it is 31 spline and useless for a hot rod application). Open drive lower shaft with steel yoke and aluminum seal plate. The internals are mint - the cleanest I've ever seen - there was a painted finish on the outside that I've mostly removed and it likely protected the magnesium as it looks very nice on the outside as well. 23/25 spur gears for 3.48/4.11 ratios. Includes a set of closed-end polished steel rear cover nuts and the cool gold finished steel ones seen in the last pics. I have it securely packaged in a plywood box. $3200 USD plus shipping.
BTTT - I also have late model mag sidebells and steel axle tubes with Ford big bearing axle ends - $500 USD extra for those.
