Technical Magnesium wheels
Discussion in 'The Hokey Ass Message Board' started by DJRODS, Apr 26, 2023.
  1. DJRODS
    DJRODS
    from WI
    Magnesium wheels best way to seal and what to use , mine leak down after awhile. Not the one pictured
  2. tractorguy
    tractorguy
    Way back in the late 70's early 80's Chevrolet issued a bulletin for very slow leaks in Corvette factory aluminum wheels. I involved epoxy paint on the inside surfaces if I remember correctly.
    427 sleeper likes this.
  3. maneri
    maneri
    from ohio
    inter tubes or carry air pump
  4. j hansen
    j hansen
    Yes...
    Deuces, 427 sleeper and deathrowdave like this.
  5. deathrowdave
    deathrowdave
    from NKy
    I ran tubes in the mags that I had for years . Sometimes tubes would stick to inside of the rim also . Baby Powder was my fix for this , don’t know if correct or not , but it worked .
  6. Yes they do. But it's a very slow leakage. I just keep check on the air. And also the oil, Q.C. fluid, water, ect. It's just part of the fun of a Hot Rod. lol :rolleyes:
    tractorguy and lowrd like this.
  7. pirate
    pirate
    from Alabama
    If you live near an industrial city Google “vacuum impregnation” it is a process where resins/plastics are used to seal porosity in castings. Here is an example: https://www.sharrettsplating.com/ad...involves the removal,create a leak-proof seal.
    Many foundries or customers of foundries routinely vacuum impregnate aluminum/magnesium casting either before or after machining to insure no leakage of fluids or gases. You might Google to see if there is a company local to you. There are numerous foundries in Wisconsin so there’s a good chance. At one time there was a source in Milwaukee.
