Technical Magnetic base drill presses...
Discussion in 'The Hokey Ass Message Board' started by canning, Jun 22, 2021.
  1. canning
    canning
    Are they of any value for light engine machining jobs? i.e. broken studs, valve seats, etc.
  2. Beepx22
    Beepx22
    The toolmakers where I work them for a lot of stuff. Including drilling out busted bolts
    loudbang and oldiron 440 like this.
  3. Mike VV
    Mike VV
    from SoCal
    For ensuring "good" mag. based drill operation, you'll NEED to have a steady/firm, flat base in which to attach the drill.
    Machining...? For "drilling" a hole for broken bolt removal, for the addition of new holes/threads, yes, a good choice if you have access to one.
    For "machining"...in place of a proper mill, or other dedicated machine...NO, I would NOT use a mag. based drill.
    Mike
  4. Moriarity
    Moriarity
    SUPER MODERATOR
    Yup, we had those at work and used them for drilling holes in the platens of the presses when needed. And it is true that you need a flat machined surface with enough m*** for the magnet to adhere to. they have their purpose but I can't think of many automotive uses
    warbird1 and Desoto291Hemi like this.
  5. I had one briefly (only because I got a deal), but it just wasn't that useful so I sold it. If the base doesn't have full contact, it will move around. A large, production-style drill press will be more useful, but at that price level it isn't that much further to mill of some sort.
  6. tb33anda3rd
    tb33anda3rd
    I have used mine on a head to get a broken exhaust stud out, it drilled it perfectly but other than that one time it has been used on my welding bench like a drill press. I will never get rid of it.
    loudbang and fauj like this.
  7. leadsled
    leadsled
    In addition to the prior comments about broken bolt extraction, you call also use a mag base for annular cutters. I have used a mag base for spot facing. If you want to do any in-place machining call Climax, trust me you will end up pulling the car apart first
  8. Wrench97
    Wrench97
    A number of years ago we changed a rear suspension in a cab over KW from torsion bar to air ride.
    After I set it up and marked where the holes in the frame went one the guys helping brought a mag base drill press there were 4 of them on the left side trying hold the drill press up and catch it if it came loose and just me on the right side with a vintage van dorn 1/2" D handle drill and a pipe. When the 4 of them finished I already had 3 slices of pizza and 2 beers.
    I you have a good flat horizontal surface it may be of use but in the strange places you drill holes in automotive they are limited.
    loudbang and Truckdoctor Andy like this.
  9. warhorseracing
    warhorseracing
    from cameron wv
    Used alot in the heavy truck and equipment repair field but not so much automotive use.
  10. Kiwi 4d
    Kiwi 4d
    I last used my rotabroach to drill several 1” holes in 1”1/4 plate ,just like ****er . Cant imagine anything in the automotive field having a flat enough surface .
  11. Like Wrench 97 and Warhorseracing mentioned, we have one at work and it’s used primarily for reframing heavy trucks. Ours is a low profile job that has rotobroach type cutters. Drills like a houseafire!
    loudbang and warhorseracing like this.
