Make a better Plasma Cutter TECH.
Discussion in 'The Hokey Ass Message Board' started by CTFuzz, Mar 11, 2005.
  1. Here's what we did to our plasma cutter to make it a LOT easier to handle................
    This was made from scraps laying around the shop, old router handles, old drill motor switch, welding shield lens and ball bearing rollers.
  2. Drivers view.
  3. We built this to cut 2" steel........it worked great.......these rollers make almost too easy to roll it around, I think it needs a little drag on it.
  4. Here I just finished cutting a circle (5') out of 1 inch Aluminum.....looks ragged but it cleans up very easy.
    It works even easier and cleaner on light stock like 3/8" or 1/4".........I think I'll start my exhaust flanges monday!!
  5. Hot Rod To Hell
    Hot Rod To Hell
    from Flint MI
    Awesome! Never would've thought of it!
    Oh wait... I don't have a plasma cutter... YET!
  6. I should add, my brother is the one who designed and built this unit..........smart guy, no?
  7. Clark
    Clark
    Cool!! That must be one hell of a plaz to cut 2".
    Clark
  8. noboD
    noboD
    CTFuzz, have you ever made patterns for your plasma? I make them from masonite {sp?}, half the diameter of the torch head smaller then I want, clamp them in place and drag the torch right around the pattern. Saw them on band saw, sand the edges, you could use wood if you wanted. I've used the same pattern several times and they don't burn up.
  9. noboD
    noboD
    Oh, and BTW, I like your rig. I might have to copy it, if you didn't TM it yet.
  10. Hole Shot Garage
    Hole Shot Garage
    How is the trigger or switch wired ?.. it looks like you can't pull the trigger.
    and yes very Smart guy !!
  11. loogy
    loogy
    What in the hell is your brother working on in that picture?
  12. I haven't tried a pattern yet, but I do use a straight edge on the long straights. Trigger is very easy to pull, actually I pull the trigger then lock it in place. The trigger is from a drill.
    We make art out of metal..................These things sell for more than a '32 hi-boy....!:confused: This is the piece we are working on. Crappy picture..........6000 LBS and 12 foot high.............
  13. FiddyFour
    FiddyFour
    DAMN nice tech :D , but SHIT that sculpture is insane!!!!!! :eek:
  14. AssGasket
    AssGasket
    Clark says cutting while looking through welding glass is un-cool.... ;)
  15. aedan
    aedan
    from ###
    too true
  16. Believe it or not, after they are painted people pay $140,000.00 for this piece of "art".........:rolleyes:
    We don't make anything near that $ to build them........the artist's foundation gets the big bucks. We do have a good time making them.
    Here's an 8 foot Aluminum piece I just finished, reddy for paint..........
    By the way, you MUST use eye protection using a plasma cutter.....what else would you use if not a welding shield??........you wouldn't be able to see for days without it!
