Making a Gasser Clone for the street
Discussion in 'The Hokey Ass Message Board' started by Hotwheels1570, Apr 12, 2006.
  1. Hotwheels1570
    Hotwheels1570
    Possibly have a chance to buy a 54 chevy.What straight axel would be best to use and what is the best way to put it on any suggestions appreciated. Later Hotwheels1570
  2. Animal
    Animal
    Using the search function for "straight axle" or "g***er" will no doubt keep you busy, as this is discussed quite frequently.
  3. brandon
    brandon
    sounds like someone is build a fullsize revell kit.....hahahah brandon
  4. Aaron51chevy
    Aaron51chevy
    I just want to know what a g***er clone is??
  5. triton6972
    triton6972
    Ive seen people use 40 ford front suspensions, with split bones and 40 ford crossmember. I got a 40 ford cross member if you decide to go that route.
  6. Flipper
    Flipper
    from Kentucky
    My guess would be a poser car with no balls. Pro-Street Version 2.0
  7. You can follow the build on my '56 here:
    http://www.blackandbrew.com/stuff/mycars/my56/56g***er.htm
    Or my buddies '55 here:
    http://www.rebelrodscarclub.com/members/lonniecobb/55straightaxle.htm
    We tried to answer alot or your questions when we put this info up on the web. I don't see why it would be any different for the '54. Hope this helps.
  8. 53sled
    53sled
    from KCMO
    this was parked next to me at 05 hamb drags. he's running i-beams in between stock front end and frame for the lift, small block and trac-bars in the rear. pretty cool, but i can't remember names very well.
  9. 46stude
    46stude
    I pulled the above quote off the '55 build page. What exactly is that measurement? I'm thinking maybe one of those Chebby truck axles might work for my build if its the right width. Anybody know off-hand?
  10. Kurt
    Kurt
    Thats my car. If you want some info or better pics i can help. The car was originally built in '65, so some early backyard tricks here.
  11. flynstone
    flynstone
    if you can find a old 65 chevy van ,that axel works well
  12. Roadsters.com
    Roadsters.com
    Often, it's a nineteen-second car that looks like it could run in the sixteens.
    Dave Mann
    (602) 233-8400 weekdays
    http://www.roadsters.com/
  13. Chili Phil
    Chili Phil
    Street g***ers are the new red wheels and flat black.
  14. Godzilla
    Godzilla
    "Clone car" sounds too much like "clown car" to suit me. Put some balls in it and make it a real street g***er. That way you won't have to drive around with a fish bowl in the p***enger's seat.
