Projects Making A Lightweight Hen Rob Torch
Discussion in 'The Hokey Ass Message Board' started by Jere, Dec 24, 2025.
  1. Jere
    Jere
    from Willits CA
    If you would like to reduce the weight of your Dillon, Hen-Rob, Cobra, DHC 2000 welding torch you need to watch this video. I will show you step by step how you can remove almost a half pound of weight.
  2. goldmountain
    goldmountain
    I'm chicken. Going to leave my Henrob torch alone. I'm too capable of messing up a good thing.
    king4144 and rattlecanrods like this.
  3. lostone
    lostone
    from kansas
    Nice work, I'd be too afraid too !
    I can see though were the loss of the weight would be a great advantage when doing long p***es.
  4. rockable
    rockable
    I'd like to sell mine, if anyone is interested. Drop me a PM.
    saltflats likes this.
  5. Kiwi 4d
    Kiwi 4d
    Because…???? Why ??? You can ?.?.
  6. G-son
    G-son
    from Sweden
    It can be a bit heavy in the long run. Still, I think I'll leave mine alone, if I get another one I might try removing some weight on that.
  7. Sandcrab
    Sandcrab
    I had a spare torch, so I spent an afternoon on it. I did it without de-soldering or extensive hand work and still approached the 1/2 lb weight savings. As shown here I used a different lightening pattern than Jere on the handle. 142.jpg
    I have not used it since the modification but the difference is noticeable.
    Lighter hoses would also be a desirable addition to reduce fatigue.
    Okie Pete, bchctybob and lostone like this.
  8. Nacifan
    Nacifan
    I've got 2 to sell.....
  9. williebill
    williebill
    Pros and cons of Henrobs?
  10. G-son
    G-son
    from Sweden
    Downsides are basically about the size and weight of it.
    Upsides...
    Is said to use less gas then conventional torches. (I have not used other torches enough to know if that is correct.)
    Very nice, calm and focused flame, providing focused heat. Great for welding, less good for large area heating to bend 2" pipe...
    Impressive cutting capabilities. Lots of demos on youtube.
    williebill likes this.
  11. stuart in mn
    stuart in mn
    Speed holes! :) Ought to make it faster.
    Okie Pete and G-son like this.
  12. G-son
    G-son
    from Sweden
    Henrob, not Homer.
  13. Jere
    Jere
    from Willits CA
    I have the lightweight hoses on my web site. they come with the "B" fittings that will adapt them to your torch.
  14. saltflats
    saltflats
    from Missouri
    I have one, used it a little. For me it's awkward just because I'm so used to using a regular Victor torch. It would just take more time for me to get comfortable with one.
