Technical Making my own fuel/brake line brackets
Discussion in 'The Hokey Ass Message Board' started by lostone, Jun 8, 2024.
  1. lostone
    lostone
    from kansas
    If anyone has followed along with my builds up to this point they know I've about hand fab'd everything, frame, frame xmembers, headlight stands, grille etc.
    So when it came time to mount gas and brake lines the brackets wouldn't be any different! I couldn't find any brackets that fit what I wanted, factory looking, simple, small and in the sizes I needed. So I made a bracket by hand shaping and liked the out come. Well not really sure how many I would need once the job was done I decided to build a jig.
    I wanted to be able to use a jig that was fast to use, easy to use, simple and repeatable. It worked out great. I cut some 5/8" x 4-1/2" long strips of 20 Guage sheet metal for the brackets, built the jig out of a piece of 2"x 2-1/4" x 1/4" strap. Then I used a 1-3/4" long pieces of 3/16" & 3/8" round rod for the gas and brake lines.
    I spaced the rods up off of the 1/4" plate the same thickness of the 20 gauge straps and welded them to the plate. Next up I built a little anvil that taps the strip down around the 3/16" rod.
    Once it was done all that's required is slide the 20 gauge strip down under the rods, slide it up tight against the upper stop I welded on, then by hand roll the strip over the big 3/8" rod, then take the anvil and a hammer and tap the strip on down around the smaller 3/16" rod.
    Once that's done, slide the strip/now bracket off of the jig, cut the excess of the strip off of the top of the bracket to match the length of the original leg of the bracket that you had against the stop. Drill a hole for your bolt and either paint or plasti-dip!
    Takes me about 3 minutes to bend and shape the brackets minus drilling the hole.
    So my jig met all my criteria ! Easy to build, easy to use, fast and repeatable!!
    Here's some pics !
    20240528_135548.jpg 20240528_135926.jpg 20240528_135926.jpg 20240528_140004.jpg 20240528_141018.jpg 20240529_160844.jpg 20240607_150459.jpg
  2. deuceguy
    deuceguy
    They look great. Nice simple idea for the jig.
    Sharpone, Tow Truck Tom and lostone like this.
  3. Kerrynzl
    Kerrynzl
    I was thinking "why waste your time" until I scrolled down and saw they were cool "double brackets"
    Well done!!! [you win the "chocolate fish" this week]
  4. 19Eddy30
    19Eddy30
    from VA
    Neat cool thinking ,
    On your way to be a
    """Coach Builder ""
    Sharpone, lostone and Tow Truck Tom like this.
  5. lostone
    lostone
    from kansas
    Thanks guys !!
    Used it again today, I needed another clamp !!
    Okie Pete and Sharpone like this.
  6. Mr48chev
    I was there with Kerrinzi and then like him saw the end product. Slick as all get out.
    Johnboy34, lostone and Sharpone like this.
  7. 1952henry
    1952henry
    Nice job!
  8. alanp561
    alanp561
  9. NoSurf
    NoSurf
    Very spiffy.
    lostone, Speccie and Sharpone like this.
  10. GordonC
    GordonC
    I'm sitting here thinking you guys have way too much time on your hands, but damned if it didn't come out very nice! Good job!
  11. tim troutman
    tim troutman
    very nice
  12. What's going on with the frame for it to go from horizontal to nearly vertical? Is it on its side?
    lostone likes this.
  13. patsurf
    patsurf
    isn't it just the widening?
    lostone likes this.
  14. 57JoeFoMoPar
    57JoeFoMoPar
    Great idea and excellent execution. Just another approach that I've used in the past, is to take two regular line clamps, orient one up and one down, and secure them with one fastener.
    I love using these combination drill taps. For this application I generally use a 10-32 machine screw, which is fine enough that you can tap frame rails and have enough meat to not worry about stripping the threads. Just fire one of these bad boys in the impact driver and you can make fast work of securing lines by combining your drilling and tapping operation.
  15. vtx1800
    vtx1800
    I wish I'd have thought of that idea:( Now if I can just remember it if I need to make clips, really slick!!
    Sharpone and lostone like this.
  16. lostone
    lostone
    from kansas
    @GordonC they don't make a clamp like that in the sizes I needed. So it was make one or try to figure something else out. This turned out to be the best way for me.
    @57JoeFoMoPar I looked at those but I needed the lines closer together to fit between the crossmembers. I wanted to keep the lines as straight as possible, I like looking down and seeing fuel, brake etc. lines running straight down a straight frame rail, don't care seeing lines curving up and down to clear stuff unless absolutely necessary.
    @sgtlethargic yes the frame is setting on the side, easier to drill holes. That picture is the rear kick up area over the rear axle...
    swade41, X-cpe, Okie Pete and 4 others like this.
  17. -Brent-
    -Brent-
    Awesome! I've been looking for the exact same thing!
  18. continentaljohn
    continentaljohn
    Great tech and love the fixture thanks for sharing
    lothiandon1940, Sharpone and lostone like this.
  19. bubba55
    bubba55
    Dare I say it - yea I will
    “ The only thing slack about you is yer looks”
    Nicely done Sir - continue onward
  20. i7083
    i7083
    Slick! Now I have to make one...
    continentaljohn and lostone like this.
  21. Dino 64
    Dino 64
    from Virginia
    Nice job !!
    lostone and lothiandon1940 like this.
  22. Okie Pete
    Okie Pete
    Thanks for sharing Your idea . Looks great .
    lostone likes this.
  23. lostone
    lostone
    from kansas
    Just a brief update !
    I took the clamps, added a couple coats of spray on plasti-dip inside and out. Let that cure a couple days then a couple coats of satin black dupli-color spray bomb to match the powder coating and to seal the pours of the plasti-dip. Installed just to see how well they looked.
    Love it ! They do exactly what I wanted. Hold the lines parallel, non-intrusive, fit the lines straight thru the crossmembers and the best part ? They almost totally dissappear!!
    I like the clean, subtle look and I got it, still need to straighten and align both lines....
    Kelly Burns, Damon777, F-ONE and 3 others like this.
  24. Royalshifter
    Royalshifter
    Moderator
    Those are great I dig home made and low buck that is why a huge percent of folks are here at this site.
    Kelly Burns and lostone like this.
