Making water transfer decals permanent
Discussion in 'The Hokey Ass Message Board' started by Hellfish, Jun 15, 2005.
  1. Hellfish
    Hellfish
    I understand that there is no real "sticky" side to vintage water transfer decals so you can put them on the inside of the gl*** looking out... right?
    OK, once you do that, what can you do to keep them from tearing or rubbing off when you clean your windows, or bump into them?
  2. Thirdyfivepickup
    Thirdyfivepickup
    I've heard clear nail polish works, but never tried it. I don't know how it would affect the decal...
    ...so basically I should have kept my mouth shut...:rolleyes::p
  3. loogy
    loogy
    Why not just cut out some clear packing tape and apply over the decal.
  4. Hellfish
    Hellfish
    because it may not be wide enough and i think it would eventually peel up... but a possibility.
  5. airkooled
    airkooled
    from Royal Oak
    How about clear contact paper then?
  6. G Griffin
    G Griffin
    My old former WAC aunt had some military decals on the inside window of her '56 Bel-Air.
    She masked off an area slightly larger than the decals and shot it with a clear, shellac.
    Lasted forever.
    G.
  7. flashback
    flashback
    There is a product called Clear Shield made by Clear Star Coatings Corp. I've used over wide format prints. It is waterbased and does'nt cause the prints to smear like mineral spirit based products. It has UV inhibitors and is abrasion and chemical resistant. I buy it in a can and it can be applied by brush, roller or sprayed. As mentioned before, you could mask it a 1/16" to a 1/8" outside your decal and brush, roll or spray a coat or two.
    Hope this helps.
  8. Hi*Speed
    Hi*Speed
    Clear nail polish works just fine if the transfer itself is in good condition. I hesitantly put it on an original Roth water transfer and it has looked and held up great since. As with paint though be sure to apply it thin, or it will run like hell.
  9. Django
    Django
    from Chicago
    airbrush frisket. Cut out a piece larger than the decal, apply, and trim with an xacto knife. It's heavy duty. Just vinyl really. I have some on my Marilyn Monroe guitar that I put on when my arm started rubbing off the paint. It has held up well for the last 15 years. The tattoo guitar has some on it as well.
  10. Automotive Stud
    Automotive Stud
    I had a 50's or early 60's mallory water slide decal, when I tried to use it, it fell apart when water touched it :(
  11. marq
    marq
    Traditional way is to use size or varnish .Don't use anything with cellulose in it.Most Brit motorcycle people use wood varnish............Marq
  12. Gr8ballsofir
    Gr8ballsofir
    what's "size"?? For us yanks...
  13. delaware george
    delaware george
    from camden, de
    size is a transfer glue like they use for doing gold leaf...one shot makes a brush on clear that the put over gold leaf that would probably work.
  14. Judd
    Judd
    GO to the nearest hobby shop and get some Solviset decal setting solution, Walter part #904-470
  15. Nail Polish Has been used in the Telecom industry (long time) for the labeling the Racks and shelf locations for components.
    I can see it now... a bunch of "Greasy Guys" buying up all the nail polish...!!!:D
  16. No no no!
    Wath are you doooing hello! With your complethion you shoudlnt go with that shade. I would rethcommend a lighter, warmer tone to compliment your eyeths and your methican blanket interior. oh my god, isth that waxth in your hair! someone get me a champagne and a latte-mocha, thith guy needs a makeover!
    Danny
  17. sodbuster
    sodbuster
    from Kansas
    Clear nail polish........but make sure you let the layers dry all the way before painting a second coat.
    Chris Nelson
    Kansas
  18. airkooled
    airkooled
    from Royal Oak
    Here's another one of those weird time warp posts. I'm thinking Hellfish probably found the answer by now since he originally posted in June.
  19. Normspeed
    Normspeed
    I'm glad it time warped. I had the same question in my head.
  20. Automotive Stud
    Automotive Stud
    LOL!!!
    I had no idea you were such an expert! Or such a sumthin' else... I won't go there :p
  21. Hellfish
    Hellfish
    i went with the clear shellac. It worked ok, but kiinda foggy. I think it was too cold when I sprayed, or the humidity was higher than i thought. It was on a vent window, so I just masked off and sprayed the whole window... now I'm going to go back and s****e it all off except for the sticker.
  22. hahaha... I think you do that a "Little Too Well"...!!!!:D
  23. graverobber63
    graverobber63
    Alliance Vendor
    Testor model paints makes a clear decal adhesive for making your own decals at home on a printer. Try that
  24. hey guys,
    you've found me out, I think its time I came out. Ok, here goes, I did at some stage watch Queer Eye for the Straight Guy.
    And I enjoyed it.
    The shame the shame!
    Danny
  25. FiddyFour
    FiddyFour
    queer eye for the straight decal?
    :D
  26. Muggs_Von_Yinzer
    Muggs_Von_Yinzer
    from Pittsburgh
    Great Topic, Wish it had come up earlier.. I lost a 7 color old school oval track decal because it started falling apart 15 minutes after it dried, (If anyone has a shangri la speedway sticker lemme know) I have a bunch of vintage oval track decals... And am looking for more from the western PA WV area.. If anyone has a lead on anything let me know... I do have a couple extras, and might bring them to a sticker maker and have them repopped as regualr stickes...
  27. dabirdguy
    dabirdguy
    It takes a special printer to print water slide decals. On deskjets and laser printers the color will wash right off. The one made by ALPS is the best. It has a wax based ribbon cartridge system. You can pring gold andsilver foils, WHITE, metallics, etc. You can get an ALPS 5000 the last one made for around $350. Ribbons ar expensive, but the results are awsome!!
    Glenn
