Projects **Malcolm Model A Roadster Build**
Discussion in 'The Hokey Ass Message Board' started by Malcolm, Mar 5, 2011.
  1. Lukydevl
    Lukydevl
    from Arizona
    subscibed 25 pages ago.. I DIG IT!!! I'm at the same stage with my '29 coupe.. I better get outside and get to work before it gets ****in hotter...
  2. Fuzzy Knight
    Fuzzy Knight
    from Santee, Ca
    Malcolm
    You and I most definitely have the same tastes. As I was looking through this thread I noticed we have the same gas tank and Battery in the exact same location!!!!
  3. trakrodstr
    trakrodstr
    Malcolm,
    I just caught up on your beautiful build thread. There’s not too many laudatory words left to choose from. You’re doing a terrific job, and you have lots of fans who are waiting for your roadster’s coming out party.
    Try to stay cool in this heat wave. Perhaps when the weather cools a bit a pilgrimage to Omaha might be in order — to see your creation. By then my TR should be reliable enough for a one day journey.
    Keep up the good work.
    charlie
    aka trakrodstr
  4. lowtruck
    lowtruck
    from Omaha
    This is really shaping up nice. I love the lower shock mounts on the front.
    Glad to see you're back at it...this thing's going to be killer.
  5. Fuzzy Knight
    Fuzzy Knight
    from Santee, Ca
    Malcolm
    Here is the intake you need for your Roadster!!!
  6. Malcolm
    Malcolm
    from Nebraska
    Yep, that means you can drive it, too! :)
    Thanks for making the trip up to Omaha, hopefully you enjoyed your time here and visit to the Speedway Motors Museum of American Speed.
    Funny you mention that, I actually checked around for an old couch before buying that hide.
    Thanks, Dale... I'll see you there!
    It has been HOT here lately, too. Quite a few 100 degree days and no AC in the garage, but I keep plugging away.
  7. Malcolm
    Malcolm
    from Nebraska
    Have made some more good progress.
    Finally picked up the correct length brake hoses for the front, so brakes are completely plumbed. Just need to bleed them.
    Also cleaned, re-gasketed, and ***embled the engine. It looked nice and clean inside, so I hope it'll run just fine.
    Since I routed the exhaust under the car, there isn't much room for clutch linkage or an external slave cylinder. I decided to use a RAM hydraulic throwout bearing. Having never installed one before, I think the instructions included with it absolutely ****. Also, the guide pin wasn't included in the kit. One call to Speedway and they rounded one up for me. I looked up instructions online and they made much more sense. Took some measurements three times, shimmed the bearing, bolted the engine to the trans, and I'm confident it is installed correctly. We shall see soon enough!
    Set the engine/trans in yesterday, will finish plumbing the t-o bearing tonight and bleed it and the brakes.
    My buddy, Clint, that covered the seat, offered to help with the body. He cleaned up and painted the underside and inside of the body. He will also be spraying bedliner underneath tonight.
    (sorry about the ****py pic)
  8. HOTRODPRIMER
    HOTRODPRIMER
    The frame looks great,,looks like your on a roll again! HRP
  9. ToddJ
    ToddJ
    from Marion, IA
    Ch***is and drivetrain are looking great, Nick. Also cool to see the underside of the body and inside are painted. You gotta be getting pretty stoked by now, man! I'll be looking for you in Salina!!!
  10. bobo1
    bobo1
    from France
    Very good job on your roadster
  11. odins701
    odins701
  12. 30TudorSedan
    30TudorSedan
    Looking good! Now all you have to do is throw a steering column on that ch***is and go for a drive!
  13. ryno
    ryno
    someones getting close to having a driving hot rod...
    frame looks really good in person fellas, the whole build does for that matter.
    thanks for taking me around the hood, enjoyed the speedway experience,just my attention span was going quickly, that and having a 6 hr drive ahead of me.......
  14. Malcolm
    Malcolm
    from Nebraska
    Body is painted inside and on the bottom side. Also sprayed bedliner on the bottom side.
    Body goes back on the frame tomorrow!
    193257
    Nick
    Man its lookin good. Keep at it and hope you make it to B Ville. Rick
  16. Malcolm
    Malcolm
    from Nebraska
    Bolted the body back down on Sunday and started re***embly. There are still a few things I need to fabricate and/or figure out small brackets, etc. It's coming together, though.
    Figured out a new mounting location for the taillights, since the old nerf/taillight bar just wasn't growing on me. I'll get a better photo of the new location tonight.
    Also messed with the dash some last night. Push-****on starter fits perfectly in the old windshield crank location in the dash 'waterfall'. I found the old on/off switch at a swap meet and it fit perfectly in the V8 ashtray location. The connections on the back of it are rather small, so I'm not sure how much amperage it could handle. It will not be wired up, just a dummy switch.
  17. norms30a
    norms30a
    That dash looks really good I admire your vision, wish I had more.
  18. JeffreyJames
    JeffreyJames
    from SUGAR CITY
    Looking good Nick!!!!!
  19. ToddJ
    ToddJ
    from Marion, IA
    Man, that dash looks so good. I dig the push****on starter location and the 'dummy' On/Off switch.
  20. poboyross
    poboyross
    from West TN
    Every time I see an update on your build, I have to change my britches. Can't wait to see it done!
  21. Tim
    Tim
    from KCMO
    man id better got buy a new terry cloth towel to bring with me when i see this mean machine in person, wouldnt want to leave a pool of drool around for some one to slip on ;)
  22. Looking pretty cool Nick. As for the low amperage switch, you could use it to switch a relay, and run your headlights or something, that would be neat.
  23. Fuzzy Knight
    Fuzzy Knight
    from Santee, Ca
    I like your gauge layout Hell I like the gauges!!!
    Mine
  24. lowtruck
    lowtruck
    from Omaha
    Nick, this thing looks better every time I check on it. Keep it up, man. Your doing a hell of a job.
  25. NTAPHSE
    NTAPHSE
  26. lukey
    lukey
    Looking really good man! Hey, it was really nice meeting you the other night! Thanks again for the springs
  27. kisam
    kisam
    Looks great Nick...almost done!
  28. ryno
    ryno
    alright dude, weekends over
    wheres the updates?
  29. There was some electronic spaghetti pictured on his instagram feed...
  30. Sweet build Nick, really coming out nice. I love the dash.
