I have recently bought a Mallory Distributor for my Y block (272) and wanted to know a bit more about it. For starters it's a YC336HP, searched the web and found nothing! I see people with YC311HP, is there much difference? Any info will be appreciated, thanks. Trev.
Here is a thread that was started by Xon regarding his Mallory dual point unit rebuilt by Bubba. Worth the read and may help you out. http://www.jalopyjournal.com/forum/showthread.php?t=866024
Trevwood, My catalogs show the Mallory 311 as being correct for the 55-56 272 and 292 engines. The 336 is shown as a 57-59 312 application. There could be a difference in the drive gear, lower end and oil pump drives between the two units.. I think the Y Blocks used a tang drive, and a couple different sizes of oil pump drives....????????
Had some good info come from the Y Block forum that said there is no difference in gears and oil drive shaft between the 336 and 311, so it's good to go. Trev.
