Mallory Distributor Identification
Discussion in 'Off Topic Hot Rods & Customs' started by Brett Becker, Feb 28, 2025.
  1. Brett Becker
    Brett Becker
    Anyone have any clue what this is for? Click on the images to see larger version.
    Mallory Billet Compe***ion Distributor
    Part #: 5457815
    Model: YH
    Thanks,
    Brett
  2. squirrel
  3. tubman
    tubman
    Is that a six cylinder distributor? It's hard to tell from the pictures.
  4. squirrel
    There are four terminal towers between the cap attaching screws, so it's a V8.
    Truckdoctor Andy and Deuces like this.
  5. Brett Becker
    Brett Becker
    ***uming this is the correct way to measure it, it is 4.25" dead on making it either:
    Chrysler 331/354 Hemi – 4.25″
    Dodge 315/325 Hemi – 4.25″
    I don't see an advance mechanism unless its built in internally and in the bottom:
    Thanks for the info!!!!
    Brett
  6. 19Eddy30
    19Eddy30
    from VA
    To me a Newer model after Unlite , used with box , EFi , I would think its BBM maybe a catalog 2010 -18 ,
    Before Holley
    If you hold shaft , Amy movement in rotor ****on ?
    That will tell you Lock out ,
    I still think its a 1st , 2nd gen used with a Ecu or Box .
  7. squirrel
    like Eddy says, try holding the bottom of the shaft, see if the rotor will turn clockwise a little bit, with spring resistance. That would be mechanical advance. If it is "locked out", then the rotor and shaft will be solidly connected together.
  8. Brett Becker
    Brett Becker
    While holding the bottom of the shaft, the rotor head turns counter-clockwise a small amount. When turning clockwise it is locked. Does that make it a big block version?
  9. 19Eddy30
    19Eddy30
    from VA
    looks to be BB Mopar ,,
    its Front mount Most likely
    & counterClock rotation & with advancement.
    Maybe reverse rotation for rear mount but that thinking outside the box.
    I can not remember if 53 ish F-H ford has a gear on disturber shaft?
    Someone will answer
  10. tubman
    tubman
    If you mean "flathead Ford", yeah, they have a gear on the end. I'm with @squirrel, that's a Mopar unit.
    Deuces likes this.
  11. 19Eddy30
    19Eddy30
    from VA
    I am also thinking its after The induction of 9,000 series distributors
  12. tubman
    tubman
    I collect vintage Mallory distributors and have zero interest in stuff like this.
    squirrel and Moriarity like this.
  13. Moriarity
    Moriarity
    SUPER MODERATOR
    moved to the off topic forum
  14. 24riverview
    24riverview
    Part #: 5457815
    Deuces likes this.
  15. Deuces
    Deuces
    I thought so......
  16. Brett Becker
    Brett Becker
    Huge thanks!!! This solves the mystery.
    Brett
    squirrel likes this.
  17. 19Eddy30
    19Eddy30
    from VA
    @Moriarity
    Just Curious about what year
    Released ? Did not see a date of catalogue
    Op maybe Stamp part # on the housing
  18. squirrel
    it's off topic just because it has the word "billet" in the name! :)
    19Eddy30 likes this.
  19. 19Eddy30
    19Eddy30
    from VA
    @Moriarity disregard !
    I see 2004 now bottom
    Left corner ,
  20. Brett Becker
    Brett Becker
    That was put there by a fax machine. There is no identifiable information except the part number and type:
    Part #: 5457815 which is stamped into placard
    and Type: YH which is a separate label
  21. Flatrod17
    Flatrod17
    The 5457815 number is not in my 2005 catalog. I believe it is a big block Chrysler 440, 426, etc.
    Deuces likes this.
  22. 19Eddy30
    19Eddy30
    from VA
    Just off top of head & remembering things, I am sure not a Unlite module that I've seen all have been"" Red ""
    With Eye ,
    Looks to be magnetic pick up ,
    So I am wondering if it the 9000 series
    Or after , or around same time ,
    Again thinking & remembering 97 ish
    Or much later , But sure before Holley
