I have a Mallory distributor for my Ford Model A banger. Dist number 2301105. I need a cap #271 because the little carbon conductor is gone. I have searched high and low. Mallory is out of stock. Summit, Jegs etc. same. Ebay nothing. Can anyone help? Thanks
is it the red cap distributor? you may be able to use an 8 cylinder cap until you are able to find a 4 cyl one
I wonder if one of these marine mallory 4 cyl caps would work? https://powerboatsupply.com/afterma...UvdpJR8E8l74WTTXDO-Z8dDHdt4lUrURoCd9YQAvD_BwE
. i wondered the same thing, My cap is 3.25 where it sits on the distributor. They don't give dimensions
I bet if you call them they would measure one for you. I looked on Brillman's website and saw nothing for Mallory stuff...
I was there also! Thanks for coming out!!! What a great time. Did you post a thread on your adventure?
I posted this awhile back. Maybe having a different part number may help? MA12 Echlin looks like it's still available from NapaOnline but boy they are pricy! https://www.napaonline.com/en/p/ECH...V2yIsLDR5tcXSCBu9SXYryPL2-3TE8Ys7pPXt4ZIobSC3
Same on the '34 coupe. I fought dizzy issues all weekend at pinetree. Ordered a reg cap that is supposed to work on the mallory yc.
Thanks. I will go and acurately measure the diameter. So I guess if you use every other plug wire terminal the only thing affected would be the dwell?
Thinking eight lobes vs four on the point cam means 1/2 as much time for coil saturation. Probably not an issue.
My cap measures the same in the counter bore that seats on the distributor. Radial location is by a 1/8" pin that sticks out from the body and engages the slot in the cap
the 8 cyl cap uses the same pin location. the extra plug connections won't hurt anything (it won't fire into the open terminals as there is nothing to carry the current away) except looking weird
I still think this marine cap is the same.... you could ask them to measure it https://www.ebay.com/itm/2255813465...7Tod8ceA3GX6Fi6YYlaquLIw==|tkp:Bk9SR7ST8KiXaA
