Technical Mallory distributor
Discussion in 'The Hokey Ass Message Board' started by tacobill, Dec 16, 2020.
  1. tacobill
    tacobill
  2. Fordors
    Fordors
    The 11 stamped on it tells us it is for Model A and B Ford, and the Z means it has a vacuum brake. The fitting on the side can be connected to manifold vacuum to control the advance but the leather pad inside the vacuum brake housing is probably hard as a rock and ineffective. You might be able to make a replacement, or try to contact tubman here on the HAMB he may have them.
    If the rotor is p/n 24215 it has a spring loaded contact and I believe you will need the old style 24004 brown cap. I had a 324 Olds Mallory and the 24215 rotor made contact with the later 4004 black cap preventing rotation.
  3. tacobill
    tacobill
  4. Fordors
    Fordors
    Your 4215 rotor is perfect for the 4004 cap. The early brown cap commands more $$.
  5. tacobill
    tacobill
    There’s no points inside. Looks like setup for dual
  6. Harv
    Harv
    from Sydney
    I thought that the Z in Mallory coding referred to "centrifugal and vacuum advance" rather than vacuum brake. Y for centrifugal advance only. I could be wrong though.
    Cheers,
    Harv
  7. vtwhead
    vtwhead
  8. winduptoy
    winduptoy
    Wow man @tacobill, member since 2015 and first three posts. I don't have that kind of restraint
    Welcome
    Sure would like to see more of your avatar
    looks like fun and a candidate for the dizzy
  9. tacobill
    tacobill
  10. Fordors
    Fordors
    What do you think it might need other than cleaning, points and the leather piece for the vacuum brake?
    BTW, as old as it is it may use 24205 points, or maybe the later 24875's.
  11. tubman
    tubman
    I make the leather piece for the vacuum brake from the proper 12 oz .leather (which is about 1/4" thick) Unfortunately, I am in Florida for the winter and my shop is in Minnesota. If you can wait until next April, I'll send you one if you remind me then.
    F-ONE likes this.
  12. 27Fireengine
    27Fireengine
    I have a vehicle with a Mallory distributor that I cannot find anything on. It's not even on the list above.
    It's a model ZA, Type 20A. No serial number stamped on it.
  13. Moriarity
    Moriarity
    SUPER MODERATOR
    according to my list, it is for a 6cyl. Mack truck
