Technical Mallory Four Lobe Service
Discussion in 'The Hokey Ass Message Board' started by GMC BUBBA, Nov 9, 2017.
  1. GMC BUBBA
    GMC BUBBA
    Lately there has been some discussion regarding the use of a Mallory 4 lobe or 8 lobe distributor cam. After rebuilding 2-3 the last couple days i felt i could help this discussion a bit.
    (I am not getting into the different operations and coils etc with the two cams as i just dont have the time )
    On this working example i set both sets of points at .018 with a feeler gauge using my very best bench procedure. In many cases this may be as good as it gets from shop to shop.
    I then put the distributor on a distributor machine and ran it. You can see the timing between cylinders is off by 5 degrees . ( Thats 10 degrees engine timing), then by adusting the contacts nwe can adjust the sync of the point set to exact cylinder timing. The only way to get one of these perfect is on a machine. To me 10 degrees of timing difference is way too much!! The old Sun testers allowed only 3 degrees .
    Note the factory Mallory jumper used on the four lobe...... IMG_2288.JPG IMG_2292.JPG IMG_2296.JPG
    loudbang, Hombre, UNSHINED 2 and 2 others like this.
  2. raven
    raven
    Please, can we have some more? I like posts like this one.
    r
    kidcampbell71 likes this.
  3. squirrel
    I wonder what the dwell variation is between the two sets of contacts, when the timing is the same?
    BurntOutOldMechanic likes this.
  4. 4wd1936
    4wd1936
    from NY
    I'll second that question, I'd like to know also.
  5. GMC BUBBA
    GMC BUBBA
    Jim, In a perfect world the dwell would be the exact same per set . I have built a few using a feeler gauge and then put it on a tester and the timing was so close i didnt change any thing. When ran as a pair one set breaks the circuit and the other set makes the circuit. So only the break set controls the timing.
    loudbang and saltflats like this.
  6. Jim didn't you offer distributer tuning classes at one time? I have an old Sun distributer machine that I'd love to know how to use correctly!
    loudbang, UNSHINED 2 and Kevin Lee like this.
  7. tubman
    tubman
    I think I'm a little "late to the party" here. Does this setup use one of the special Mallory "Rev-Pol" coils or a regular coil (as the jumper wire suggests)?
  8. UNSHINED 2
    UNSHINED 2
    Me, too!
    cactus1 likes this.
  9. belair
    belair
    Great stuff, interesting as all get out, taught by the best. But it makes my brain hurt.
    firstinsteele and kidcampbell71 like this.
  10. GMC BUBBA
    GMC BUBBA
    Yes we did a Hot Rod ignition class with 10 guys for two days , it was great and a lot of fun and everyone got to rebuild their distributor. I have tons of requests to do it again and may get around to it . However it takes a lot of time to set up and do again. Right now i just done thave the time, but stay tuned as i may do it again some day.......
    cactus1 and loudbang like this.
  11. squirrel
    Hmmm....here you are talking about a dual point distributor for a V8, with an 8 lobe rotor. But in the example I asked about, you were talking about a dual point distributor for a V8, with a 4 lobe rotor. In this type of distributor, one set of points operates every other cylinder. And you showed that the timing was different for each set of cylinders operated by each point set, then corrected it by adjusting the dwell on one set to make the timing match the other set. I'm curious how much you had to change the dwell, and how different they are now.
  12. GMC BUBBA
    GMC BUBBA
    Jim,
    I have a few in the shop to get done, i will check the dwell for each set on the next one i do. Almost all the units i do with the four lobe cam come in the door with the factory red jumper lead installed . If not i usually add it as the dual primary coil is kinda hard to find, and even harder to understand. for some.
    I ran a dual primary Mallory on my GMC six powered dragster for some time and it worked very well.
    Attached is a diagram of the first version Mag Spark coil set up , came in yesterday for rebuild , flathead Ford eight lobe cam. Points NOT wired together?? IMG_2302.JPG
    loudbang and kidcampbell71 like this.
  13. GMC BUBBA
    GMC BUBBA
    Jim, You guys seem to enjoy this stuff , heres some more explanation of the early Ford Mallory Mag Spark ...When someone figures it out write a post so i can understand it. I just dont have the time......rbg :>) IMG_2303.JPG IMG_2304.JPG IMG_2305.JPG
    warbird1 likes this.
  14. dirty old man
    dirty old man
  15. GMC BUBBA
    GMC BUBBA
    The coil with the kit is a regular coil.........NOT the Rev Pol unit.........
  16. tubman
    tubman
    OK, I think I have it. The points are jumpered together and each set alternatively energizes the single conventional coil. When you gapped the two sets of points the same, the alternate point sets didn't fire exactly 90 degrees apart, so you adjusted the gaps to bring the points back in phase. Is this a fair summary of what's going on?
    I have a complete (6 volt!) RevPol set up for an Olds Rocket. If you don't mind, I think it might be informative for me to post a few pics of it so people can see the difference. Whadya' think?
  17. kadillackid
    kadillackid
    I'm in...never too much info that can help us out.. :)
  18. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Love the question Jim. But wouldn’t that be equal to asking what timing works for all applications? I think the answer would be differant if one was fortunate to have a hand full of those distributors to test. Meaning, if you built 6 BBC exactly the same, would they all have the same dyno results?
  19. tubman
    tubman
    I think "Squirrel" may have a point. If the manufacturing tolerances on one of these would stack up completely the wrong way, It might be impossible to get the points "in phase" (firing exactly 90 degrees apart.) And if you did, it may have taken a disparity between the alternate point gap such that one may be down to .008"-.012", rather than, say a recommendation of .016" on each set. This would significantly reduce the dwell, and therefore coil saturation, and consequently spark strength. Hopefully these units were built with sufficient precision that this wouldn't happen. I think Jim said he is going to check a few. The results should be interesting.
  20. Moriarity
    Moriarity
    SUPER MODERATOR
    Ok, after reading this I grabbed a 4 lobe Mallory off the shelf and put it in my machine. In setting the points with a feeler gauge I found the arrows off by 5 degrees also. So I found a copy of the instructions for a distributor and this is what it said[​IMG]
    So I blocked a set of points and set the dwell at 17 per the instructions [​IMG][​IMG]
    Then I set the ring so it was flashing at 0,90,180 and 270. I blocked the first set and set the other to 17 and when I pulled the paper from the points they were flashing at the proper 45 degree spread[​IMG][​IMG][​IMG]
    And I had 36 degrees total dwell with both sets working. I think maybe the lesson here is to use dwell instead of feeler gauges on these
    Sent from my iPhone using The H.A.M.B. mobile app[​IMG][​IMG]
    30tudor, warbird1, loudbang and 2 others like this.
  21. GMC BUBBA
    GMC BUBBA
    Yea we got it down pat and the lesson here is that a dwell meter is the very best way to set these up!! Also remember dwell is a average reading of the complete circle.
    loudbang and Moriarity like this.
  22. saltflats
    saltflats
    from Missouri
    That is what I have been playing with on my switched duel point.
  23. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Let’s dwell. Bubba didn’t have time so he used others time to teach us instead. Yet, there was time to review?
  24. 28dreyer
    28dreyer
    from Minnesota
    I think your points are closed.
    Johnny Gee likes this.
  25. GMC BUBBA
    GMC BUBBA
    Yep that works well some times, start the discussion and stand back someone will lead on. Saves personal energy, thats what old guys do.... rbg :>)
    Moriarity, Johnny Gee and loudbang like this.
  26. Mr. Mac
    Mr. Mac
    Do you still have that old 6 powered dragster??:):)
  27. 28dreyer
    28dreyer
    from Minnesota
    And also negative grounded.
  28. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Jim had me thinking something wasn’t equal some where. But where, and how could dwell correct a flaw that’s perhaps in the distributor. That would never work. The flaw turned up else where to what I was try to say. No two things will create the same result no matter how well machined or matched.
  29. GMC BUBBA
    GMC BUBBA
    No , wish i did. We traded it off its in Minnesota with a Chevy v8 in it now.
