Mallory rev Poll question. hey Bubba ya out there?
Discussion in 'The Hokey Ass Message Board' started by porknbeaner, Dec 20, 2009.
  1. Got this screaming curiosity going on here.
    When I was a a younger man the real deal for ignition was the Mallory Rev Poll. You used to be able to get everything on a box dizzy and coil/box.
    OK as I understand it Rev Poll stood for reverse polarity.
    So here is my question for all you much more better educated than I. Was there any difference in the distributer? Or was it just the direction the current ran through the coil? or am I totally off base?
    Hey GMC Bubba ya out there somewhere?
  2. 327-365hp
    327-365hp
    from Mass
    Apparently the Rev-Pol and the Double Life are the same basic distributor with a different point and condensor set-up. Here's a thread on the subject.
    http://www.jalopyjournal.com/forum/showthread.php?t=111336
    I recently scored a NOS Rev-Pol YC 310hp for a sbc. I would like to run this thing, but I'm wondering if there's a Pertronix unit for it.
  3. Don't know about a petronix unit but I know you can go with a unilite for about the same money and they are a better ignition in my opinion.
    I was thinking perhaps different points and condensor.
  4. blown49
    blown49
    Best I can do Pork. I have a "Double Life" in my Merc only has 4 lobes. Points mounting on dizzy plate is exactly 45* apart and gapped @.022".
    Jim
  5. GMC BUBBA
    GMC BUBBA
    Beats me how i missed this one yesterday , but i did.
    from the hamb previous post above:
    Double-life:
    4-lobe cam, two separate sets of points connected together with one condensor. This is wired to a normal coil.
    The only benefit of this over a normal single point distributor is that the points last longer as each set is only firing 4 times per revolution.
    Good description !
    Rev-pol:
    4-lobe cam, two separate sets of points, each with their own condenser and wired to separate primaries on the special Rev-pol coil. This coil has a single secondary terminal that connects to the distributor cap.
    My guess is that this offers some of the benefits of a dual-coil setup without having to use two coils and a special distributor cap.
    The special twin primary ignition coil offered the same benifits of the Harmon Collins, du-coil and Grant Flamethrower offered.
    Twin contacts each operatiog its own primary. This allowed the rpm range to increase as the contacts didnt need to work but half time.
    A increased faster dwell ( coil build up) also made the sixs (3 lobe) and the eights ( four lobe) increased the available spark at higher rpm.
    I have one of theses on my gmc powered six Hambster dragster and it runs great.
    However these coils are very hard to find. But i have a couple new old stock and have yet to see a defective one.
    A typical unit will cruise at 8,000 plus all day long. ( difficult to do in 1953 !)
    Hence, if you have a Rev-pol, but can't find the special coil, you can remove the second condenser, wire the points together and run it with a normal coil.
    Questions ??
  6. igorw
    igorw
    The one I had for my 409 also had an under dash mounted switch that by-p***ed the resistor for more voltage on demand.
  7. GMC BUBBA
    GMC BUBBA
    That one worked for sure.
    I have been thinking about reproducing the little dash bracket, switch and on/off lamp. Would still work on any and all contact system etc.
    Look cool with the word "race" on it for sure........:eek:
  8. Corn Fed
    Corn Fed
    Do you have the part number for the 12V version and/or a picture of these that you could share?
  9. super plus
    super plus
    I have a complete rev pol with good points & cap for sale, $100 for sbc, no coil
  10. I've got a rev poll box/coil and a tach drive YL. I'm guessing that I'll have to do some mods to make it work together.
    Let me rephrase my coil says rev poll on it. But it seems like it only has a single primary. I'll have to look a little closer this evening and get back.
  11. GMC BUBBA
    GMC BUBBA
    Heres a couple pics...............
  12. 327-365hp
    327-365hp
    from Mass
    Thanks for posting those pics Bubba. That schematic is a big help. That Rev-Pol coil is pretty ugly. I think I'll convert mine to a regular dual point. Any idea about an electronic conversion for these? Pertonix or Mallory?
  13. GMC BUBBA
    GMC BUBBA
    One i finished today, the flatcap mallory ( my favorite on the "cool" List) With pertronix.
  14. GMC BUBBA
    GMC BUBBA
    couple more from this week...
