mallory unilite
Discussion in 'The Hokey Ass Message Board' started by hudson_hawk, Apr 7, 2005.
  1. hudson_hawk
    hudson_hawk
    i picked 1 up from honest and plan on dropping it in . do you still use the ballast resistor? and three wires. + - and whats the third for?
  2. MattA
    MattA
    from Plano, tx
    I remember that you cannot have more than 9 volts going into the dist. or you will fry the module. 7-9 volts is recommended, but it has been a while since I messed with one and I cant remember the third wire.
  3. pikesan99
    pikesan99
    Can't you get directions from Mallory's web site?
    I've used a unilite before and always ran the resistor (<-- ugly ****er that it is)
    If you can't find what you need, send me a PM and I'll see if I can find the old directions.
    The one I ran, we could never get enough advance out of it. Good luck with yours.
    Pike
  4. hudson_hawk
    hudson_hawk
    i am looking but just easier to ask. see if you have them, that would be great.
    are petronix better?
  5. KATFISH
    KATFISH
    Hawke,
    Go to www.taperformance.com/ignition
    There is a diagram there showing just what youre doing.
    Hope this helps
  6. weemark
    weemark
    from scotland
  7. KATFISH
    KATFISH
    If this wont open for you PM me
  8. squirrel
    make sure that brown wire is connected very well to a good ground connection on the engine, and that it can't come loose, or the module may blow out instantly. Supposedly they fixed the problem on later ones, but I'd rather run points than a unilite! at least you can fix points when they quite working.
  9. BELLM
    BELLM
    Go to the Mallorywebsite, tons of good reliable info., depends on which coil you are using, mine runs two resistors.
