Mallory Voltmaster and Grant Spaulding Flamethrower
Discussion in 'The Hokey Ass Message Board' started by Richard D, May 11, 2010.
  1. Whatzit?
  2. hotroddon
    hotroddon
    Voltmaster Coil, very popular in the 60's and 70's
  3. That the original price tag on that thing?
  4. How far back in the 60s?
    Rust and Dust price tag, I think I Jewed him down to $5-$10 or something.
  5. hotroddon
    hotroddon
    Can remember seeing them in 66, other than that, not sure
  6. hotrod40coupe
    hotrod40coupe
    I was running one back in '61. They worked pretty good.
  7. SuddenDeath
    SuddenDeath
    from Florida
    Bought one just like it in 1980 for a Mustang I owned while in the Corps. Worked great. As I remember, they require a resistor block to work properly.
  8. Ebbsspeed
    Ebbsspeed
    I ran one into the early 70's, along with an early Mallory electronic ignition. See that red cap on the top? That's where you can refill it with dielectric oil if it leaks out, which some of them had the habit of doing if they were not mounted with the cap at the top. They also would tend to leak around the secondary wire terminal.
  9. So I done good?
  10. hotroddon
    hotroddon
    If it still works :D you must run a ballast resistor with it. I always thought they were the coolest looking coils
  11. How can I test it? And where do I find an early 60s ballast resistor(no late model stuff)? I am sparky challenged!
  12. lakes modified
    lakes modified
    I put a few hundred thousand miles on the one I had till it crashed.They work great.The also made an electronic ignition version, check the label.
  13. JeffreyJames
    JeffreyJames
    from SUGAR CITY
    Part number 28576 or 28676 12V Ignition coil. Not sure when they were popular.
  14. Chevydeuce
    Chevydeuce
    I bought recently a couple of those.
    There was even a 6V Voltmaster coil.
    Some of ém say Magspark.
    On one I have the metal label wich said "Voltmaster" flew of and under it you could read "Magspark" in the plastik housing.
    Is there a difference between RevPoint Magspark or Voltmaster coils?
    I guess they cannot be interchangend?
  15. HEATHEN
    HEATHEN
    from SIDNEY, NY
    The "Magspark" coils were intended to be used with either a Mallory Magspark distributor, or a stock distributor with a Magspark conversion kit. The "Voltmaster" coils were intended to be used with just about any distributor.
  16. tommy
    tommy
    It is shown in Honest Charlie's 10th annual catalog in 1958. They came with some very cool looking ballast resistors mounted right on the top of the coil. They are round with a steel cover. You could probably use a generic ballast resistor but the old Mallory's resistors are cool looking if you like old hot rod parts.
  17. Tommy-
    If I get another of these, could I un them with my Spaulding Flamethrower, the one that was yours years ago?
  18. tommy
    tommy
    Edit this is from a 1954 Newhouse catalog.
    If I've got it right a Mag Spark coil has 2 windings inside that Mallory used to do the same thing that Spalding did with 2 separate coils. Each set of points only energized one side of the coil at a time. If I'm right, you would only use one side of each of these coils with the secondary wire from each going to each side of the Spalding. I'm ***uming you just want this coil for its looks.
    I'm no Mallory expert. I'd check with Bubba to see what components would work together including ballast resistors.
  19. Yep, I love the look of old stuff, otherwise I use some ugly EFI engine! I will check with Bubba for some info.
  20. alchemy
    alchemy
    Looks like a CRACKED coil. Isn't that a crack running from under the price tag to the lower right corner?
  21. shake it and listen for the oil sloshing around inside. if you don't here any it probably leaked out the crack (if that is what the line is). if no oil inside, seal the crack, carefully unbolt top and separate from the bottom slightly (don't remove). fill the case about 3/4 full with marvel mystery oil . put it back togethr and try it. i run one on my 283 and have had good luck with it.
  22. tommy
    tommy
    Is it marked 6V or 12V. I have a 6V one with the round ballast resistors as in the catalog picture. I think mine has a sticker that makes me think it's 6V. If it's 6V it's just showcase material.
  23. Oh ****, it is cracked, no sloshing. $10 wall hanger, no biggie! Bubba says he has a box of 'em.
  24. 327-365hp
    327-365hp
    from Mass
    My car has run a Voltmaster coil forever. I replaced it with this NOS one a couple of years ago. This one said "For Electronic Ignition" on it but it still worked for points. This week I switched my Mallory dual point over to Pertronix. Of course they want you to run one of their coils. So what I did was mount the Pertronix coil under the dash. I left the Voltmaster on the firewall but I gutted it and ran the coil wire into it and out the back through the firewall. BTW,You can still get the Mallory #700 ballast resistor from Jegs. http://www.jegs.com/i/Mallory/650/700/10002/-1
