Technical mallory yc-310 distributor terminal ?
Discussion in 'Traditional Hot Rods' started by demon452, Mar 24, 2014.
  1. demon452
    demon452
    from Michigan
    Can anyone tell me what type of ends go into the distributor itself? Maybe even a part number.
    Thanks in adavance
  2. Bruce Lancaster
    Bruce Lancaster
    Two piece cap Mallory? This is going to be real expensive:
    NOTHING. DONE.
    You just strip a very small amount (like 1/8 or so) off the end and splay the wires out slightly. Run your wires through the plastic outer cap and inner rubber part, shove the poor wires onto the spikes, and slide down the rubber. When you screw down the upper cap it compresses the rubber slightly and everything is secure forever.
  3. demon452
    demon452
    from Michigan
    Wow, rather funny I didn't think of that. Kinda like a rajah terminal (speedway one's). Duh.
    Thanks a lot and pretty damn cheap.
  4. Bruce Lancaster
    Bruce Lancaster
    I'll email you everything you need. CLICK. No problem, I have a whole bin of Mallory terminals.
  5. tommy
    tommy
    Just remember it will need to be 7mm wire and not the modern 8mm thick wire. And then you can use Rajah clips on the plug ends. I like Packard 440 wires just out of 50 years of habit.
