Manifold Idenity
Discussion in 'The Hokey Ass Message Board' started by Powell Ric, Aug 21, 2012.
  1. Powell Ric
    Powell Ric
    from Powell Mo.
    Any one ever seen a manifold tunnel ram type adapter like this? I took it to the hamb drags and no one ever saw one before, I found it years ago laying next to a old small block ford offy. 2- 4bbl manifold it fit on it perfect to go from 2- 4's to a single 4 , it looks like it could be used either way, it is steel NOT cast , about 1/2 said it was homemade and 1/2 thought it was factory.
  2. prewarcars4me
    prewarcars4me
    from Bhc, AZ
    Those welds say home made to me.
  3. Well it could be to go from 2 fours to one or from 1 four to two, depends on what it is mounts on and which end is up I suppose. I would guess it is hime made myself unless I could find some markings of some sort on it.
  4. Powell Ric
    Powell Ric
    from Powell Mo.
    the more I look at it , it looks home made or experimental but how would you make that one piece center section? or what is is from?
  5. Atwater Mike
    Atwater Mike
    Roswell...1948. The military picked most of 'em up...said they were 'moorings for weather balloons. Hah!
  6. prewarcars4me
    prewarcars4me
    from Bhc, AZ
    No idea, but hot rodders have been adapting other parts from ANYTHING from a long time.
  7. squirrel
    show us what the two flange side looks like. Wonder if it's designed to fit an early dual quad intake? if so it would have flanges that would fit the WCFB type four barrels.
  8. Powell Ric
    Powell Ric
    from Powell Mo.
    it fit the old offy dual quad intake perfectly
  9. Oilcan Harry
    Oilcan Harry
    from INDY
    Maybe an adapter for racing where the rules varry allowing 2 carbs at some tracks and a single at others. The Edelbrock Slingshot has two different easy to change tops available for one carb to two.
