Technical manual clutch linkage ideas
Discussion in 'Traditional Hot Rods' started by onegalonly, Mar 6, 2014.
  1. onegalonly
    onegalonly
    where can i find some good pictures of manual clutch linkage set ups.. im stumped on trying to figure something out on my hiboy.. any help will be appreciated
  2. pasadenahotrod
    pasadenahotrod
    from Texas
    What engine/trans combination do you have? In what ch***is?
  3. onegalonly
    onegalonly
    here's a pic.. right now, i have a hydraulic throwout bearing installed.. it is about 1" deeper than a manual throwout bearing.. i had to use a 1/4" spacer between the engine and bellhousing (dont like it) but still dont have enouth pedal to disengage the clutch.. im taking it out and puting a bearing and fork in it.. but stumped on linkage.. im also thing of using a slave cylinder, either push or pull... my clutch master cylinder is wilwood 3/4" bore.. engine is 350 chevy, trans is saginaw 4 speed
  4. onegalonly
    onegalonly
  5. highboy
    highboy
    from marin
    I use The Willwood master with the 62 chevy pickup slave. both bores are equal, think they're 3/4. you just have to fabricate a bracket for the slave which is a pretty basic design. It points toward the rear of the car and pushes the fork
  6. onegalonly
    onegalonly
    i'll look into that slave cylinder
  7. onegalonly
    onegalonly
    rock auto shows the bore size for 62 chevy pickup slave to be 1"
  8. bobby_Socks
    bobby_Socks
    from ǑǃƕǑ
  9. highboy
    highboy
    from marin
    Well if memory serves me. My Willwood is 1 inch too...But lately my memory seems to be on strike.
  10. vtx1800
    vtx1800
    Here is a manual clutch set that I cobbled together for my 38 Chevy, nothing fancy, just functional.
  11. onegalonly
    onegalonly
    is your pedal soft or hard with both bores being equal?
  12. highboy
    highboy
    from marin
    It's pretty soft. even in traffic it's no problem. Vtx 1800 is another good route. if you look at any mid sixties or early seventies chevy pick up they use a similar manual bar mounted to the frame and on the side of the block where that pivot ball is bolted. i've seen many of these at any pick n pull with a good selection of trucks and you can get all the three parts(frame bracket,cross bar,and the pivot ball needed for cheap. they're not as sanitary as the hydraulic but they work better. GM must have figured that out cause they stopped using hydraulic clutch systems after two years i think
  13. Shaggy
    Shaggy
    from Sultan, WA
    Vern tardel makes a copy of the old ansen one that is ***s in an old hot rod if you don't mind It being on the firewall(I'm gunna chrome my master/slave cylinder
  14. scootrz1
    scootrz1
    from usa
    I pretty much copied my 1969 dodges and used the Z bar cut down to fit on 32 style frame made every thing to fit running big block mopar with 4 speed
  15. wuga
    wuga
  16. onegalonly
    onegalonly
    i saw the novak system before.. it needs 2" of space.. i cut that real close to my exhaust pipe that i'm dumping down in fornt of the firewall to run the exhaust out back
