Manual or automatic for a Nailhead
Discussion in 'The Hokey Ass Message Board' started by broderchamp, Sep 15, 2012.
  1. broderchamp
    broderchamp
    I'm going to put a 65 Nailhead in my model A and I have a NWC T-5. The motor comes with an automatic. Which of the two tranmissions would be a better way to go.
  2. steel rebel
    steel rebel
    Probably a lot more trouble but three pedals is the way to go.
  3. TagMan
    TagMan
    Ultimately up to you, but I'd also go the 3-pedal route. There's just something about shifting through the gears as opposed to blandly sitting behind a steering wheel that really turns me on!
  4. '37 Buick floor shift would be the ticket and very traditional or a Lasalle. Yea, no OD but what the hell we did not have it back in the day.
  5. TexasSpeed
    TexasSpeed
    from Texas
    The T5 has more gears than the automatic, is more fun to drive, and better for you economically..
    I don't see any reason why you'd want an automatic. :)
  6. desotot
    desotot
    hmmm, a model A What size shoes do you wear?
  7. Mike Moreau
    Mike Moreau
    The only reason to NOT install the manual is the $1,100 or so to buy the trans adapter, flywheel, clutch assembly, clutch fork, and pilot bushing. Bob Bendtsten (sp?) has high quality kits to lighten your wallet and get you a stick shift kit that is ready to install. He is at 763 767 4480 in Wisconsin if I remember correctly.
  8. Hnstray
    Hnstray
    from Quincy, IL
    also can be found at www.transmissionadapters.com .........Makes good stuff. Quality is seldom cheap.
    Ray
  9. That's what I'm putting behind my Naily
  10. 39 Ford
    39 Ford
    The Buick may have to much torque for the T-5 especally if you run big tires and do some burnouts in a heavier car.
  11. striper
    striper
    Lucky mine are only size 9s. If I'm doing any serious driving I always wear Chucks. No room for boots. (Chanelling doesn't help either)
    Back to the original question...more trouble to fit a 4 or 5 speed, but I wouldn't change a thing.
    Pete
  12. 48FordFanatic
    48FordFanatic
    from Maine
  13. Hnstray
    Hnstray
    from Quincy, IL
    As for manual or automatic......no one else's opinion matters one whit!
    It's YOU that has to be satisfied with the outcome........do what pleases you!
    Ray
  14. GassersGarage
    GassersGarage
    How much traffic do you run into? How often will you drive it? Traffic conditions in your area? I used to drive sticks, but in LA County, traffic is so bad, I now have automatics. As an added plus, my wife can drive my cars now in a pinch.
  15. I like too shift gears too. Go for the manual. A T-5 will hold up to a lot, don't worry about it, Model A is not a heavy car. ;)
