manual trans for a '60 389?
Discussion in 'The Hokey Ass Message Board' started by forsakenfew, Oct 12, 2006.
  1. forsakenfew
    forsakenfew
    from seattle
    thinking about switching out the th350 for a manual this winter. (this is in my 31 sedan) am i stuck with the 59-60 factory stuff?? i know without the spendy adapter, i was stuck with the original automatic.
  2. specialk
    specialk
    389 poncho? Wikipedia http://en.wikipedia.org/wiki/Pontiac_V8_engine#389 says this was the same engine from 1959 - 1966. Is that not true?
  3. forsakenfew
    forsakenfew
    from seattle
    pretty much the same internally, but the 59-60's are kind of their own en***y with other things, like bellhousing bolt pattern.
  4. Yessir....the '61 and newer Pontiac has a different "back of engine block". You'll need to find a '60 or earlier bell and go from there.
  5. HEATHEN
    HEATHEN
    from SIDNEY, NY
    A '55-'60 flywheel will work, but a '58-'60 bell housing is what you'll be looking for. The '55-'57 bells were flanged for those ****y "selector" type three speeds that have a unique bolt pattern.
  6. forsakenfew
    forsakenfew
    from seattle
    ok, this is what i'm looking for...thanks!!
    now, what transmissions bolt to the bell?? sorry for the stupid questions, just not alot of experience with the manual stuff.
  7. carmak
    carmak
    Keep an eye out for a mid to late 50's GMC truck. They used Pontiac V8 engines and most of them were stick shift.
    Good luck
    Carmak
    Riverside, Iowa
  8. HEATHEN
    HEATHEN
    from SIDNEY, NY
    The '58-'60 bell has the common bolt pattern of all modern General Motors 3/4/5 speeds.
  9. b0ne dry
    b0ne dry
    from n0r*cal
    food for thought...
    my mild 389 likes to eat muncies when pushin 3800 pound cars...
    and i have a 59' 3-2 intake sitting in my storage.... if your looking for one.
  10. Not to hijack, but has anybody got a picture of the stock setup in a 59-60? More specifically, the z-bar and linkage?
    I'm changing my 60 to a stick, and I've got damn near everything to do it--I just wanna make sure
    Sorry for ****in' in, and thanks in advance!
  11. axle
    axle
    from Drag City
    your info is 100% correct. be prepared,this **** is hard to find. i have this stuff but not letting go of it.
  12. HEATHEN
    HEATHEN
    from SIDNEY, NY
    Here's a tip--if you're patrolling a swap meet and see an aftermarket transmission adapter that looks somewhat like an early Olds, but not EXACTLY like an early Olds, it's a '55-'60 Pontiac adapter intended to be used in conjunction with the front half of a stock hydramatic bell housing. I've seen guys try to p*** them off as Olds adapters before.
  13. mpls|cafe|racer
    mpls|cafe|racer
    You are right!
    This is what you are looking for. I lucked out and got this stuff with my 389 from the seller for an extra $50.00. Ended up paying like $200.00 for everything.
    Keep your eyes on the lookout though, like others have said, this **** does turn up once in awhile!
  14. axle
    axle
    from Drag City
    my flywheel is bad if anyone has an extra they want to part with?
  15. HEATHEN
    HEATHEN
    from SIDNEY, NY
    How bad is bad? Can it be resurfaced? If not, pm me.
