Manual trans for my 301
Discussion in 'The Hokey Ass Message Board' started by motormaniac, Apr 27, 2004.
  1. motormaniac
    motormaniac
    I have been thinking about sticking a manual transmission on my 301 Chrysler and I would like to know from the experts here on the HAMB what is a good transmission to mate it to and where do I find an adapter plate to do so? This is going in my lakes modified Willys project and I just think a car like that needs a manual rather than the auto I have on the motor now. I plan on getting 225 horses out of the engine with a few mods. What would you guys use?
  2. Bigcheese327
    Bigcheese327
    I'll bet money that any trans that can be adapted to the back of a '50s Hemi can be adapted to your Spitfire. I haven't got any hard evidence for it, however.
    How badly do you plan to abuse this baby? I'd be seriously tempted to go Saginaw 4-speed, myself. They're cheap, plentiful and Chevy adaptors are the most readily available.
  3. Bigcheese327
    Bigcheese327
    Looks like the Wilcap ’54-58 Hemi adaptor works for your application.
    APPLICATION: V8 CHRYSLER 54-58, DODGE 53-58, DESOTO 52-58, PLYMOUTH 55-58
    TRANSMISSION: CHEVY/BOP MANUAL TRANS. USING STOCK OR AFTERMARKET BELLHOUSING
    STARTER: 1966-1999 MOPAR 2 BOLT STARTER, GEAR REDUCTION DRIVE
    FLYWHEEL: INCLUDED: STEEL OR ALUMINUM
    CLUTCH: 10.5,Äù COVER, 10.5,Äù CLUTCH DISK. AVAILABLE FROM WILCAP
    PRICE: $595 W/STEEL FLYWHEEL $645 W/ ALUMINUM FLYWHEEL EXCLUDES SHIPPING AND ANY TAX
    This is all from http://www.wilcap.com/webdoc8.htm#A392350MT
  4. Shaggy
    Shaggy
    from Sultan, WA
    Hi, well i'm plannin a chev 4 spd but they also have adapters for mopar 4 spds.
    Thanks again for the T back.
  5. lakes modified
    lakes modified
    My son was planning on doing the same thing for the 301 he is putting in his 40 willy's pickup. was going the 5 speed route, but now has changed his mind to a AOD GM unit. there are adaptors for the tremec 5 speed out there also.
  6. motormaniac
    motormaniac
    Your welcome. Where were you going to get your adapter plate? I would like to be able to find a used one. Have you had any luck finding used stuff like that?
  7. lakes modified
    lakes modified
    The only stuff he found out there was new, except for a chev. bellhousing for the 5 speed. i think it bolts to a flat plate on the back of the block..i can check with him this weekend, as he will be here, wiring our remodeling project.
