Technical manual transmission options
Discussion in 'The Hokey Ass Message Board' started by bodydropped72, Jun 20, 2024.
  1. bodydropped72
    bodydropped72
    from bako,ca
    hey all just picked up a 34 ford pickup. plan is to just throw it together on a new frame stab a small block and possibly a manual trans. my question is the motor i have as a donor came out of my dads 57 chevy with manual 3 on the tree, i was thinking of picking up a junkyard t5 out of late model camaro. it should bolt up to the bellhousing but im not sure if any different clutch/ flywheel arrangement is needed. any info out there on doing manual swaps?
  2. gimpyshotrods
    gimpyshotrods
    The 57 SBC will have a 168-tooth flywheel, and a big clutch.
    The Camaro/Firebird used a 153-tooth flywheel.
    You will need to source a big clutch with the Camaro T5 splines in the hub. They are out there.
    The Camaro/Firebird T5 will bolt up, after you enlarge the bellhousing bolt holes. Stock T5 holes are Metric.
    Google the tail housing. The T5 in an F-Body is mounted on a tilt. You will need to accommodate this.
    18-degrees.
    In the stock application the rear mount is flat.
    If you put it on a traditional bellhousing, the rear mount will be tilted 18-degrees.
  3. Ohh great, another thread that sounds shifty. Hehe.
    '34 Ratrod, Toms Dogs, lowrd and 3 others like this.
  4. Budget36
    Budget36
    If he’s sourcing a yard T5, then he could also snag the BH as well?
    I guess the FW if in good shape also.
  5. gimpyshotrods
    gimpyshotrods
    That bell uses a hydraulic slave cylinder.
    If that works for him, and the donor car was from the two-piece rear main seal years, he'd need the starter, too.
    Then a stock or equivalent F-Body clutch could be used.
  6. redo32
    redo32
    Tow Truck Tom likes this.
  7. In_The_Pink
    In_The_Pink
    The 15* rotated GM F-body setup was only in the bellhousing, so leave that behind and the T-5 will bolt up just like any other, and to a "normal" SBC bellhousing. The vent tube for the F-body T-5 is long and funky, and not really needed when the trans is rotated to the normal "straight up" clocked position.
    Tow Truck Tom and Budget36 like this.
  8. DDDenny
    Based on your thread ***le.........how about a four speed.!!!
  9. Mr48chev
    Nice but realistically at today's prices you are going to have 1000 and way up in a Muncie or Saginaw 4 speed setup once you buy transmission and shifter and they don't give Hurst Compe***ion plus shifters away. Running a 4 speed isn't in the throwing it together league anymore it is in the "That's what I want, I don't give a **** what it costs" league.
    The T 5 setup can usually be had within reason price wise but still not exactly cheap unless you are an experienced bargain hunter.
    Tow Truck Tom and Desoto291Hemi like this.
  10. gimpyshotrods
    gimpyshotrods
    You are forgetting that doing that will take the transmission mount out of level by the same amount.
  11. Budget36
    Budget36
    And considering how long that T5 has been in use, after a rebuild (if unable to do it oneself) would about rival the cost.
    2OLD2FAST likes this.
  12. gimpyshotrods
    gimpyshotrods
    They are not at all hard to rebuild.
  13. Bearing Burner
    Bearing Burner
    from W. MA
    If your throwing it together use the three speed with a floor shift conversion. Much cheaper than a T5.
    283john and williebill like this.
  14. 427 sleeper
    427 sleeper
    They should, 'Cause they ain't worth a Fiddler's **** anymore! You're better off getting one from a swap meet!
    Kerrynzl, bowie and Duellym like this.
  15. DDDenny
    Considering the last two new ones I've bought (I kind of) agree, they aren't tight right out of the box like they used to be.
    427 sleeper likes this.
  16. 427 sleeper
    427 sleeper
    Mine got hung in 2nd gear every time I semi-aggressively shifted. :mad: Had to tighten it up with spare part's I had laying around! A COMPLETE Horse**** solution for a brand new shifter, IMO!
    jazz1 and 2OLD2FAST like this.
  17. Budget36
    Budget36
    Neither are many things, but one has to be inclined to do so.
    Also have the ability.
    Not like you could have the counter help at a mini mart rebuild it.
  18. 38Chevy454
    38Chevy454
    T5s are getting scarce in junkyards. Plus they are marginal for V8 power. An option for SBC is get a NV3500 5 speed out of a 4.3 V6 or V8 S-10 or 1/2 ton full size. These have an integral bellhousing (chevy pattern) and hydraulic throwout bearing. 153 tooth flywheel. They can handle moderate power, better than T5. Just requires hydraulic vs mechanical clutch setup. Don't get the 4 cylinder version, NV1500. Not only weaker, but also wrong bellhousing bolt pattern. There's also a bigger NV4500, you don't want that either. It's bigger and slower shifting. The NV3500 is kind of sweet spot for size and power capacity. Technically there are 2 different versions of NV3500 with slightly different ratios S-10 vs full size. But close enough either will work.
    treb11 and jazz1 like this.
  19. In_The_Pink
    In_The_Pink
    True, but I'm ***uming an S-10 tailhousing swap is also in order for a '34 Ford pickup, as with the F-body tailhousing, the shifter tower would roughly protrude through the middle of the seat. :D
    I purchased this shorter/S-10 style shifter rail when I swapped my F-body tail for an S-10 unit: https://www.ebay.com/itm/285290143980
  20. Taboo56Chevy
    Taboo56Chevy
    Also need to know if your planning on recessing the firewall any for the SBC? You can get it in there without doing it, its a tight fit. You will need the S10 tail with the shifter as far forward as possible. Even without touching the firewall. F body setups have the shifter way too far back.
    My 33 pickup had a Saginaw in it when my grandpa bought it originally, they had cobbled together a Z bar and linkage to work the fork. It worked but not that great. On the chopped 34 pickup we had, it used a 61-66 Chevy pickup dual chamber master cylinder to use a hydraulic setup for the clutch.
  21. Mr48chev
    I've got my old one that my dad bought me for the M21 that was in my 48 in the late 70's for my birthday with linkage hanging in the shed and it is one of the things my kids will have to figure out what to do with some day.
    I've run a full syncro Saginaw 3 speed with a Hurst shifter that I got used for years and with the right rear end gear those are nice transmissions behind a mild engine. If money was tight that is what I would run.
    Toms Dogs likes this.
  22. Toms Dogs
    Toms Dogs
    from NJ
