Technical Manzel Buffalo Engine stand
Discussion in 'The Hokey Ass Message Board' started by Indecisivebuilder95, Jan 30, 2023.
  1. 6908207D-3DDB-4E83-B03C-CBD935F90A39.jpeg E4044849-97D4-4F74-A4E6-1A0B7ECF203F.jpeg 9F17E64F-0F8B-494F-A27D-2BA9D5F43C1E.jpeg D28B2A23-7E7A-4CC9-83C6-E43105505C83.jpeg 38E6BEEA-4AA1-46D4-BBD0-67F49F35839C.jpeg F1B49900-0543-493D-9ED7-A45F42C0517B.jpeg 985C384A-010A-4814-8E53-C482AB2A9166.jpeg 7D2F8BA2-684A-4185-97D6-F2D7D8C3B119.jpeg 55AF87D7-E601-4AFA-B6D8-45493BEB91B0.jpeg Hello everyone,
    my dad recently came into possession of his engine stand he’s had in storage for ~30 years. I’m looking for info on the attachments pictured for the Stand and what they fit. I obviously know the exhaust ones are going to be for some kind of flathead (most likely fords as we are a ford family) but the others I can not find a shred of info on. Any help is appreciated.
  2. alanp561
    alanp561
    Best I can do on short notice!
    HomeForumsGeneral DiscussionThe Hokey Ass Message Board
    FEATURES
    MANZEL ENGINE STAND
    Discussion in 'The Hokey Ass Message Board' started by linear59look, Jan 19, 2021.
    Watch Thread
    1. upload_2023-1-30_19-16-35.png linear59look
      from Cleveland, Oh
      So I have always wanted one of these or KR Wilson engine stands. The style of these stands is killer.I know they were made for use in Ford dealerships(even though I’m a GM) guy) in the 30s-50s. And the bulk of them I’ve seen have the adapter for mounting flatheads from the exhaust manifolds since the bell housings were prone to breakage. This one clearly has some sort of home made adapter. Does anyone recognize what this adapter is for? Next, I have never seen one of this style with a crank for rotating the engine. All of the ones I have seen you have to rotate the engine by hand and there is a locking lever which mounts in the 2 holes at the top of the upright. Anyone else out there seen or own one of these with the crank? Is there an adapter that exists for conventional mounting by the bell housing bolt holes so I could mount an engine other than a flathead? Or is making my own the only option? This brings me to my last question. This stand is made of cast aluminum not iron. Any knowledge of breakage or anything like that? Reason being i work on Olds/Caddy engines. Prior to buying this I assumed adapting it for the newer engines would be no big deal, but after thoroughly researching the weights, the early Olds and Caddy’s are easily 150-200lbs heavier, not to mention the increased lever arm due to the extended bell housing on early olds engines which would place added stress on the upright. Anyone ever adapted these stands for use on newer,heavier and longer engines without losing their foot over it? I will not do anything to the stand itself that would permanently change it. (Somebody already added a sort of gusset between the base and upright).
      upload_2023-1-30_19-16-35.png upload_2023-1-30_19-16-35.png upload_2023-1-30_19-16-35.png Sent from my iPhone using H.A.M.B.
      LINEAR59LOOK, JAN 19, 2021
      !REPORT!SHARE POST#1LIKE+ QUOTEREPLY
      kidcampbell71, adam401 and Unique Rustorations like this.
      Never seen one, but damned cool!
    lothiandon1940 and Budget36 like this.
  3. Thanks I saw this I’m looking for more info on the attachments themselves.
  4. alchemy
    alchemy
    Obviously the long one is for a flathead block mounting to the exhaust flanges. No idear on the weird shaped one. But my guess for the half circle mount is for banjo axle assembly. Do you have one you can hold it up to?
    alanp561 and olscrounger like this.
  5. alanp561
    alanp561
    Haven't found any attachments like yours but did find this Manzel attachment for a Ford tractor engine. From what I'm reading, it looks like the gear drive you have is the really cool thing. I saw reference to an adapter to a K.R. Wilson stand also.
    lothiandon1940 likes this.
  6. Grandadeo
    Grandadeo
    Looks like the Manzel 6005 "G" flathead mounting bracket that I've been looking for in one of the pictures.
    Lee
