March 2011 Banger Meet
Discussion in 'The Hokey Ass Message Board' started by Crazydaddyo, Mar 1, 2011.
  1. model.A.keith
    model.A.keith
    Jimski,
    I couldn't find one......it seems they are becoming a rare item.......
    Keith
  2. RoddyB34
    RoddyB34
    can you tell me about the transmission and bellhousing in the pic when you say late model ,? thanks from Rod,,
  3. kenagain
    kenagain
    from so cal
    what they really meant was it was repainted those words get mixed up a lot on bangers
  4. ebtm3
    ebtm3
    Re painted, my patootie! Most didn't even have the grunge knocked off!
    Herb
  5. godspeedbear
    godspeedbear
    from golden
    Some of you have talked about running inserts for the main bearings.. Where do I get some/ what does it take??
    Just got the quote for new babbits... Ouch!!
  6. It'll take a good machinist that knows what he's doing. You can't just pop in inserts. One of my "bangers" (a Model B that came with my race car) had babbitt mains; and inserts in the crank throws. The insert rod bearings were ones from a Standard (Brit.), the same engine in a TR-2. They were hard to find.
    My current engine has GM inserts (both mains and rods). However, I gotta tell ya: It ain't cheap. So I wouldn't have a crank breaking as often; I had one ground out of a solid piece of forging. There are girdles made to fit Ford "Bangers", that have five main bearings. My engine, that has lasted five seasons, without blowing out the bottom end, has five mains. Of course, I wind that little ****** up to 5000 rpm.
    You might just be as well off, if you're not winding your "banger" much over 2500 rpm, to go with the babbitt and a stock crank. However, babbitt or inserts, if you have any three main crank in an A or B, there's no such thing as a C (I bet I get another argument about that), you are eventually going to break that crank, if you buzz your engine above 3000 rpm. The remedy is to put a damper on the nose of the crank.:)
  7. ok i am confused
    i took a perfectly good running model b engine
    no smoke or knocks
    took it apart (pan front cover head cam and valve cover)
    replace the cam with a stipe cam and abjustable lifters
    new aluminum timing gear
    new aluminum front cover
    new gaskets
    now i have huge amounts blow by
    out the breather and out the exhaust
    smoke...blues smoke
    i pulled the plugs and they are oily
    what just happened
    literally 20 min of run time
    help
    tk
  8. BCCHOPIT
    BCCHOPIT
    OK... Old Dawg
    you cant talk about your ride with out posting LOTS OF PICS
    thanks Bill
  9. BCCHOPIT
    BCCHOPIT
    My guess...
    when you cleaned your deck of all the carbon and **** you might have got some stuff stuck in your rings:rolleyes:
  10. i didnt need to clean the pistons
    this engine was a very recent rebuild
    i was thinking maybe a head gasket, so i just went and did a compression test with about 60 lbs across the board
    stock b head
    tk
  11. BCCHOPIT
    BCCHOPIT
    do all the plugs have oil?
  12. yep
    tk
  13. BCCHOPIT
    BCCHOPIT
    I will give you 50 bucks for it
  14. BCCHOPIT
    BCCHOPIT
    I would run it some more and see if it clears up. There is no oil on the top so it has to come from the pistons
    Did you put too much oil in it after you put it back together?
  15. no i checked it
    i was thinking about just running it to see
    maybe a few good heat cycles
    its still colder than hell here and have no roof is hindering my street time
    maybe i'll bundle up tomorrow and hot lap it aroun the neighborhood
    tk
  16. BCCHOPIT
    BCCHOPIT
    Sounds like fun. Can I come? You would have to pick me up but it would be better then a day at work
  17. sure how many quarts of oil do you think it would take to get from Illinois to torrington. Maybe Steve henkle can ride along lol
    tk
  18. I recently purchased 2 sets of those triumph inserts through E bay, rods and mains Std and .010
  19. Bluto
    Bluto
    I've a couple hundred sets but I am in the US now and they are in Europe
    I can report in about 6 weeks
  20. kevins29truck
    kevins29truck
    from ohio
    tub in da dirt, did you hone your cylinders to break the glaze when you had it apart? and did you put new rings in? if you honed it and put the old rings back in that can be your problem.
  21. kevins29truck
    kevins29truck
    from ohio
    2 questions, anyone have cam specs on a gemsa full race A cam for a T block. and would the harmonic balancer that speedway sells for a flathead v8 work on a banger? isnt the crank snout for an A or B the same as a v8?
  22. BCCHOPIT
    BCCHOPIT
  23. I talked to Chris at pancakes this weekend about you Bill.-Weeks
  24. BCCHOPIT
    BCCHOPIT
    I didn't do it...:rolleyes:
  25. Brendan1959
    Brendan1959
    Thanks, I got on to pearsons and I now have a nice set of rubber pedals on my A.
    Brendan
  26. BCCHOPIT
    BCCHOPIT
    Any Banger guys and girls going to the Lone Star Round Up in TX????
  27. March Meets earlier this month, only Banger there. Drove out had a great time drove home like usual. Even my biddy Model A Dave didn't drive his red banger powered 40 pickup. He was under the alias of Model T Steve this year with his *****en flathead v8 powered T. Surprised the hellout of him how fast I drove in. I figure about 65 tops which is not really anything too crazy, just caught me off gaurd when we got the gas station and he said that. Heres some pics of my endeavor fellas.-Weeks
  28. There's been a bunch of photos of my car posted on the HAMB. I thought, perhaps I was over doing it. Here's some more.:)
    Thanks,
    Don't need none of that "furr'n" car stuff no more; I sold the engine to a hotrodder that was putting it in a LSR car:eek:
  29. BCCHOPIT
    BCCHOPIT
    I did see the your very cool car.I just didn't put you with it sorry. I think it would be cool if you posted pics every week that car will never get old in my eyes
    thanks again
    Bill
  30. Thanks Bill,
    I guess the new organizers of the Monterey event, "The Rolex Monterey Motor Sports Reunion", finally, after nine years of appearances, got tired of seeing it. I just got word, the day before yesterday, that the little car will not be invited to the event this year. We will be running at Steve Earle's Sonoma Historic Motor Sports Reunion at Infineon Raceway (Sears Point), the first weekend of June. The last of April, we'll be running it at VARA's Route 66 Cl***ic, on the two mile, AAA Speedway oval. We're trying to get enough "pre-war" cars to run an event on the infield road course there. As that weekend gets closer, I'll remind the SoCal folks. That Route 66 Cl***ic is the greatest bargain in today's motor racing. For $10.00 (kids under 12 fee), spectators can get a three day p*** to the exhibitions and races;)
