Technical ***March 2022 Banger Meet Thread - Another Equinox***
Discussion in 'Traditional Hot Rods' started by Jiminy, Mar 1, 2022.
  1. Jiminy
    Jiminy
    Link to previous month: February 2022
    Coming Events: (PM Jiminy with additions/corrections)
    September 18 Auburn, CA NorCal F.A.S.T. Fall Hill Climb
    Stay safe.
    For the HAMB banger newbies, here are some links to a lot of banger info:
    Jim Brierley's book 4-bangers! And me! is a must read book for all banger enthusiasts. US customers send $34.00 all color except for the oldest pictures (includes S/H in the U.S.A.), PayPal welcome, to:
    Jim Brierley, 39480 Colleen Way, Temecula, CA 92592.
    email: jimb4e4@gmail.com
    phone: 951-695-7313.
    A few links to speed equipment companies there maybe more
    https://specialtymotorcams.com/index.php#header
    http://www.millerhi-speedheads.com/index.html
    http://www.modelatrader.com/brumfield/brumfield.html
    https://www.hotforhotfours.com/advertisers.htm
    https://www.secretsofspeed.com/speed-parts
    Bert's, Synder's, Mikes affordable also list some speed performance parts.
    Here is a list of most of the prior monthly banger meet links:
    http://www.jalopyjournal.com/forum/s...d.php?t=161498
    Banger basics. another info link list:
    http://www.fordgarage.com/
    http://www.plucks329s.org/index.htm
    http://www.jalopyjournal.com/forum/s...d.php?t=251717
    http://www.jalopyjournal.com/forum/s...ad.php?t=42480
    The link below shows flywheel lightening dimensions
    http://www.jalopyjournal.com/forum/threads/may-bang-er-thread.470853/page-4#post-5212157
    and this link shows the missing image from the above post
    http://www.jalopyjournal.com/forum/...-work-on-bangers.1010716/page-3#post-11427055
    The 4 Banger hot rod picture thread.
    http://www.jalopyjournal.com/forum/threads/the-4-banger-hot-rod-picture-thread.997051/
    Model B rod bearing insert numbers
    http://www.jalopyjournal.com/forum/showthread.php?p=6992484#post6992484
    Engine tuning with a Vacuum gauge
    http://web.archive.org/web/20120415...e.com/tuning-with-a-vacuum-gauge-spg-148.html
    Adjusting dual Strombergs:
    http://www.jalopyjournal.com/forum/showthread.php?p=6638461#post6638461
    Helpful Model A tools and tips:
    http://www.maurer-markus.ch/ford_a/tipps.index.en.html
    Gary in MN's late model Malory distributor conversion for A/B engine:
    http://www.jalopyjournal.com/forum/showpost.php?p=9147025&postcount=109
    Elrod's stuck head tech:
    http://www.jalopyjournal.com/forum/showthread.php?t=218487
    Model A generator to alternator conversion:
    http://ejwhitneyco.com/automotive.html
    Gear ratio / speed and RPM calculator:
    http://www.accuautoparts.com/calculator.php
    Model A master cylinder mounting bracket ideas:
    http://www.jalopyjournal.com/forum/s...73#post4953173
    Go here to read the 1931 edition of Harry Ricardo's book "The High Speed Internal Combustion Engine"
    http://www.scribd.com/full/40610101?access_key=key-w2bcjicdancrnxypd05
    Chevy Banger Stuff
    http://www.jalopyjournal.com/forum/s...d.php?t=463465
    Post 198 starts a great discussion of the shape of a flat head combustion chamber
    http://www.jalopyjournal.com/forum/showthread.php?t=470853&page=10
    T-5 5 speed in a Torque Tube:
    http://www.jalopyjournal.com/forum/showthread.php?t=256226
    New Banger Block in the Works
    http://www.jalopyjournal.com/forum/threads/new-banger-block-in-the-works.616056/
    Model A & B Style Cast Iron Cylinder Head Compression Ratios.
    http://www.fordgarage.com/pages/headcompressionratio.htm
  2. 62pan
    62pan
    Checking in.
  3. noboD
    noboD
    Is spring here yet?
  4. don't rush it....
    winduptoy likes this.
  5. Kevin Pharis
    Kevin Pharis
    from Califunny
    Dropped off my new Winfield at a polishing shop... should have it back in a couple weeks with all the nooks and crannies sparkling like jewelry! Hoping to have some up close pics soon...:D
    Carter, burl, Jet96 and 8 others like this.
  6. denis4x4
    denis4x4
    from Colorado
    Checking in with my semi traditional banger powered with a 1935 CRAGER head
  7. The37Kid
    The37Kid
    DSCF9155.JPG Equinox, like Mt. Equinox in Vermont were this car was racing in an SCCA Hill Climb around 1953. I found the remains in September of 1971 and later sold them to Jim Etter around 1979.
    DSCF9156.JPG DSCF9157.JPG Yesterday I found a two page letter (remember them, before the computers) from Jim asking me about the condition of the frame and body parts. He did put axles under it with Ford V8 wire wheels, and installed an A engine, and had a running car at a meet in Ohio, Dover I think. He sold it and lost track of who he sold it to. Lots of good things have happened in the past 51 years, but I WANT TO FIND THIS CAR. Any and all tips are welcome, thanks! Bob
    Jim riding as mechanic in the car in 1980, the only photo I've seen after I sold the remains.
    Tman, stillrunners, Carter and 9 others like this.
  8. Lurking as usual.
    panhead_pete and winduptoy like this.
  9. stubbsrodandcustom
    stubbsrodandcustom
    from Spring tx
    Braved the cold and wet and went to Hotrod Showdown this last weekend. Random pic from driving around. Adjusted the valves, and hooked up my oil pressure gauge that maybe is too high to actually work right on a banger.
  10. Dustyp489
    Dustyp489
    Checking in, getting a slow start getting back to the A
  11. blgitn
    blgitn
    Lurking in....
    stillrunners likes this.
  12. V4F
    V4F
    from middle ca.
    nuttin new here
  13. brjnelson
    brjnelson
    I have never seen a Himico before, if I wanted to go slower I would buy this.
    1925 MODEL T ROADSTER PICKUP WITH ***LE. VERY RARE EARLY ORIGINAL 1925 PICKUP BOX. VERY SOLID BODY WITH ONLY RUST BEING UNDER THE P***ENGER SIDE DOOR. NEW WOOD KIT ($1800) INCLUDED. WINDSHIELD AND FIREWALL REMOVED BUT INCLUDED. RUCKSTELL 2 SPEED BIG DRUM REAR AXLE WITH H***LER PANCAKE SHOCKS. INCREDIBLY RARE HIMICO BUILT ENGINE/TRANSMISSION. ENGINE HAS HIMICO INTAKE, HIMICO EXHAUST, HIMICO CYLINDER HEAD, HIMICO TAG ON SIDE OF BLOCK. THIS IS THE ONLY KNOWN EXAMPLE OF A COMPLETE HIMICO ENGINE/TRANSMISSION SETUP. WINFIELD MODEL M201A CARBURETOR. A****ER KENT FRONT PLATE DISTRIBUTOR. H***LER PANCAKE FRONT SHOCKS, 26-27 NICKEL GRILL SHELL AND HEADLIGHT RINGS, ORIGINAL WOOD RIMS WITH NICE TIRES, NEW SEAT SPRINGS, NEW LEFT HAND RUCKSTELL SHIFTER. I WOULD TRADE THIS FOR A RUNNING DRIVING MODEL A ROADSTER OR ROADSTER PICKUP. TIM [hidden information]
    burl, Jet96, blgitn and 3 others like this.
  14. There WILL be a Ford "Bangers" time trials at the Historic Santa Margarita Ranch this year! It's just a matter of when! I'll meet with the ranch owner next week. We may have a choice of late June; or late September/early October. Late June carries a potential of high temperatures. The September date would be either week earlier of later than the RPM Nationals! What do you participants think?
    Jet96 and winduptoy like this.
  15. kweb1936
    kweb1936
    from salem il.
  16. Time to ***emble May is just around the corner
    burl, Phil Damon, Old Dawg and 2 others like this.
  17. V4F
    V4F
    from middle ca.
    john , dont be late !! how fast are you going this year ? .......... good luck ! ... steve
  18. railcarmover
    railcarmover
    Gas station in West Virginia “ hey, did you drive that from California?”…
    Jet96 likes this.
  19. BeaverMatt
    BeaverMatt
    Does anyone know if there will be a "hill climb" in Northern Cal this year? I believe there had been one in May or June pre-Covid and pre-FAST ending. Was it in Auburn?
  20. Hey Steve,
    Yeah, thanks, if, if, if, hopefully faster than last year.
    The cam was pretty beat up, welding and grinding.
    I don't know how fast the car will go, but at the current rate we are going to Hell in a hurry.
    John
    Old Dawg likes this.
  21. That would be fantastic, as I'm in Lompoc I'll definitely be coming up!
  22. Been a hot minute since I've posted on the banger forum, raising a baby will do that!
    Super excited to finally finish the first run of side timing covers. Took some 3d modeling cl***es, and turned it to a reality!
    As I want to have a few projects to work on, what would be other bolt-ons that you'd like to see made?
  23. brokenspoke
    brokenspoke
    How about timing cover with oil filter
    Gasolinedeniz likes this.
  24. Stovebolt
    Stovebolt
    Hi guys. I'm still lerking, but not posting.
    I have a question regarding balancers.
    My coupe is powered by a winfield headed B motor. I mainly drive it around town (metropolitan traffic) with the occasional trip on the freeways, where I cruise on 55mph. It has an alternator.
    Trouble is the balancer is worn and rocks on the crank. So do I replace it with an original sized one, or a smaller diameter one from Scalded Dog?
    I'd appreciate your input before I make my purchase.
    Cheers.
    Mark
  25. Hibernation continues in Brrmont.
  26. guitarguy
    guitarguy
    Been watching this on Instagram, GREAT JOB!! We need more like you to be able to step up to the plate so to speak and start carrying this stuff on. It is a tough limited market, but anything anyone does to help the hobby like this is a win in my opinion.
    I have been quite busy myself to partake on forums and IG / Facebook, But I was shock recently to learn of so much Model T stuff disappearing at a rapid rate in the last 2-3 years. No more gas tanks, No more radiators, No more Model T haven, No more Fun Project parts, No more RV Anderson supplied small parts, No more Stan Howe Carburetors, and I am sure there is a bunch more I am forgetting.
    Genes12320 likes this.
  27. Phil Damon
    Phil Damon
    from San Diego
    Checking in. T5 is done. Going through rear axle now. Can't wait to get it back together and start driving it.
    Genes12320 and Old Dawg like this.
  28. That's already done. Really no point in trying to make something that's already out!
  29. Thank you man! Someone's gotta carry the torch! I'd love to meet up with Jim Brierly to pick his brain.
    My buddy is thinking about selling this T engine, apparently its mated to a 4 speed. Side Draft Riley Carbs, Chain driven oil pump and Mag IMG_9948.jpeg
    v8flat44, Old Dawg and Jet96 like this.
  30. Retson,
    Those look really nice good job.
    I was thinking of the Burtz motor and something that might make sense would be a filter mount that would discharge the oil directly into the galley port instead of using the bottom bolt. Or just add the boss to your existing model and oring the port.
    Keep up the good work, J
    Gerald Sleater and Old Dawg like this.
