Technical ***March 2025 Banger Meet Thread - In Like A Lion, Out Like A Lamb***
Discussion in 'Traditional Hot Rods' started by Jiminy, Mar 3, 2025.
  1. Fabber McGee
    Fabber McGee
    Double flare is best, no thin sharp edge to crack. Single flare is fine with soft material like copper and fairly low pressure. Compression is fast to ***emble... that's the only advantage I can see. Compression is used a lot on trucks with plastic tubing for air controls, but they have a steel sleeve inside the tube to compress against and if air leaks slightly, so what? Low pressure fuel lines on my old 6.9 diesel use fat rubber ferrules successfully, but, of course, diesel is not nearly as flammable as gas.
    My opinion, do the best you can on everything you do and you'll have far fewer problems in the future. As alchemy said, "Why risk it?".
  2. jim1932
    jim1932
    Well the stock is a compression fitting. That said, I can always use a new tool. Time to learn flaring lines.
  3. Fabber McGee
    Fabber McGee
    I used one of these for nearly 50 years, not always successfully on the first try.
    A couple years ago I said phuket and paid the extra dough for one of these.
    What a difference in the quality of the result. However, if you have to fix a line under the car in a restricted space the first one is the one you (meaning I) need.
    jet996 likes this.
  4. Stovebolt
    Stovebolt
    I used one of these tools to make a single flare for the 5/16” fuel line today.
    It works really well for that purpose too.
    Fabber McGee likes this.
  5. Fabber McGee
    Fabber McGee
    I haven't tried it yet, but I think the propaganda for the fancy one said it will bulge fuel lines too.
  6. jim1932
    jim1932
    I just ordered the ***an 1/4" and 3/16" we will see how it goes. Looking to do a couil something like this, but on a B Motor form pump to the dual carbs.
  7. Steves46
    Steves46
    from Florida
    Does anyone know who’s fabricating the Finned Side Timing Inspection Covers?
  8. Dedsoto
    Dedsoto
    from Australia
    I got mine from Petes over on the East coast of Australia
    jet996 likes this.
  9. Steves46
    Steves46
    from Florida
    Thanks and appreciate your reply. Actually I am looking for the small timing gear inspection side cover. I can recall a year or two go seeing somebody that was fabricating them however I can’t find any information.
    Dedsoto likes this.
  10. hotrodA
    hotrodA
  11. Steves46
    Steves46
    from Florida
  12. hotrodA
    hotrodA
    Hold up. These are side drive. Here are pics.
    He MAY also make the covers though.
  13. Dan from Oakland
    Dan from Oakland
    Charlie Yap has some side covers available.
  14. Stovebolt
    Stovebolt
    ‘last weekend I partook in the 15th Annual Black Forest Run.
    250 trouble free miles, starting off in drizzling rain, ending in bumper to bumper traffic as I drove through the city, as I crossed from west to east of the city.
    It was a fantastic run. Pre-42 cars. Great bunch of entrants.
    2 bangers powered cars, 3 with Mechanical brakes.
  15. Jiminy
    Jiminy
