Technical ***March 2026 Banger Meet Thread - Time Changes***
Discussion in 'Traditional Hot Rods' started by Jiminy, Mar 1, 2026.
  1. Deutscher
    Deutscher
    from Germany
    The front fenders are mounted; they were battered, so I sanded and polished them with 1000-grit wet sandpaper. They look quite presentable again.
    Cheers, Harald
    winduptoy, 282doorUK, jet996 and 5 others like this.
  2. wheeltramp brian
    wheeltramp brian
    Haven't checked in in a while since I sold my banger powered Cabriolet a couple years back but I'm hoping to get back in the game. Got a friend who has a rebuilt B motor in a crate and is looking to sell but doesn't have an idea what he wants. I'd like to make him an offer and be fair,any ideas? Also have a nice ch***is to put it in and then I'll find a body
  3. Outback
    Outback
    from NE Vic, Oz
    Ca
    Can't help with a figure but it's worth a bump
    winduptoy and Deutscher like this.
  4. meteorpete
    meteorpete
    Looking to get some education on mounting a downdraft intake with open ended mounting flanges leaving half the mounting washers hanging out in space. I'm using a full flange Red's header. Doesn't look right to me. How have others addressed this? Thanks. IMG_8172.JPG
    winduptoy, Deutscher and chlsnk like this.
  5. GuyW
    GuyW
    I'd make machined spacers (steel?, alum?) to exactly fill the gaps. Compression/friction should hold the spacers in place, but I suppose the washer and spacer could be drilled for a pin or small screw to ensure the spacers remain in place (ie not lost) even if they come loose.
    Machining the intake ears thinner doesn't seem like a good idea to me.
    winduptoy, chlsnk and Dannerr like this.
  6. wuga
    wuga
    I also mount mine like that. is there a better way?
    winduptoy likes this.
  7. GuyW
    GuyW
    The unsupported bolt is going to tend to bend away from the intake flange (even if the intake flange surface is flat and parallel with the head). The easiest solution seems to me to be to shim the unsupported half.
  8. jet996
    jet996
    from WY
    IMG_1050.jpeg This is how I did mine, has worked great for quite a while.
    marioD, winduptoy, mvee33 and 6 others like this.
  9. wuga
    wuga
    Chevy used something like that on the 235 I6. I like the idea.
    Warren
  10. I've used heavy wall tube before and cut one side away to the depth of the manifold flange. I'll get a picture later.
  11. GuyW
    GuyW
    Is that stud bent or is it just my eyes?
  12. Deutscher
    Deutscher
    from Germany
    That's how I attached mine too.
    Greetings Harald
    marioD, winduptoy, Outback and 3 others like this.
  13. meteorpete
    meteorpete
    I got a piece of 1 inch square solid aluminum tubing. Will try making some solid spacers tomorrow. And perhaps some way to fasten it as per GuyW. I like the angle iron idea as well but will try solid aluminum first (idea being the same material will expand and contract the same). Thanks everyone. I only have basic tools so we'll see how it goes! Will report back when complete.
    winduptoy, Outback, Dannerr and 2 others like this.
  14. jet996
    jet996
    from WY
    @GuyW it's a weird lens distortion or something. It's def not that wonky in real life:)
  15. jet996
    jet996
    from WY
    If any of you guys are looking for a good banger project my coupe is over in cl***ifieds.
  16. wuga
    wuga
    Was a slow month.
    Warren
    Outback, Deutscher and winduptoy like this.
  17. winduptoy
    winduptoy
    Had my water jet buddy cut a bunch out...
    marioD, G Baese, jet996 and 1 other person like this.
  18. winduptoy
    winduptoy
    April fools Day @Jiminy is messing with us
    jet996 and Outback like this.
  19. Jiminy
    Jiminy
  20. wuga
    wuga
    I was just talking to Charlie Yapp about the stud problem and he informed me that they used to cast the intake with full flanges and that everyone complained so they started casting only with crows feet. He told me that Red's Headers sold a solution which I think is pretty close to what has been proposed here. I have contacted them and am awaiting a reply. I can make the stand-offs, but am curious as to what they had. I also mentioned about making the standoff using aluminum bar and he felt it would collapse when torqued on and would distort the readings. I know it is April, but it is hard to continue a conversation in the next month.
    Warren
    winduptoy, jet996 and Outback like this.
  21. meteorpete
    meteorpete
    That's clean. I like that.
    winduptoy and Outback like this.
  22. burl
    burl
    from Minnesota
    my solution but time consuming just a chuck of aluminum round stock with hole through center cut in half
    marioD, Motordr32, meteorpete and 6 others like this.
  23. winduptoy
    winduptoy
    It takes a longer stud....Ace Hardware had them...
    Outback and meteorpete like this.
