marine 427
Discussion in 'The Hokey Ass Message Board' started by jho, Nov 14, 2008.
  1. jho
    jho
    from Omaha
    hello are the marine ford 427 engines worth anything
  2. Malcolm
    Malcolm
    from Nebraska
    Hello Jason. Welcome to the HAMB.
    I'll give you a case of Busch Light for one of those 427s haha....:D
    Malcolm
  3. dirtbag13
    dirtbag13
    let me know where to pick it up i'll give you the going s**** price !:D
  4. 36 ROKIT
    36 ROKIT
    They certainly are; but check out the block and head i.d. numbers to be sure its not a
    428. (In fact, some of these were built by Holman and Moody)
    One big caveat, however, try to determine if it was used in salt water!!
  5. Troublemaker427
    Troublemaker427
    Just beware if they've been used in salt water or are reverse rotation.
  6. 067chevy
    067chevy
    Welcome to the Hamb Jason.
  7. Michigander
    Michigander
    This info applies to the standard marine "Crusader 427" engines from Ford.
    If the engine had a salt water open cooling system, p*** on it. An open fresh water cooling engine may be OK, if inspected. The closed cooling system units should be OK too.
    The block will be the only real value. They are center oiler, solid lifter only engines. If there is any flakey rust in the water jackets, it may be too thin around the cylinders. A .030" overbore is max, and they are thin to start with. Freeze cracks are VERY common, look in the lifter valley and on the block sides.
    The rods are Cobra Jet parts, and are in some demand. The iron front cover can be used as a engine mount, so rodders may want it. The distributor is a Mallory dual point.
    The rest is garden variety boat anchor FE parts, i.e. heads, crank, intake, etc. Reverse rotation engines only effected the cam, distrubutor drive gear, the rear seal knurls on the crank, and starter, so no big deal there to correct.
    A clean block (no water jacket rust or cracks) that can clean up at .020" is worth about $1500. Since repo blocks came out, OEM iron parts aren't is such high demand with the rubber Cobra builders.
    Keep your eye out for replacement service blocks, could be later side oilers.
    Steve.
  8. str8enough
    str8enough
    from Omaha, NE
    I got 2 cases on one!!:D
