Technical Marine carburetors:
Discussion in 'The Hokey Ass Message Board' started by c-10 simplex, Feb 4, 2016.
  1. c-10 simplex
    c-10 simplex
    What are the differences between a "marine" carburetor and a regular carb?
    This then begs the next question, Can i(should i) use a marine carb on my car?
  2. gnichols
    gnichols
    from Tampa, FL
    They constantly complain about Navy food. Gary
    volvobrynk, Nailhead Jason and Jet96 like this.
  3. 55willys
    55willys
    Some marine carbs don't have an accelerator pump because they are designed to bring the rpm up slower and run at a constant rpm.
  4. V8 Bob
    V8 Bob
    The main difference, at least on 4150/60 Holleys, are the curved bowl vent tubes that direct any overflow back into the engine. They will work fine on the street.
    Holley 0-9015-1 - Holley Marine 4-bbl
  5. HOTRODPRIMER
    HOTRODPRIMER
    About 2oo bucks,the marine carburetor is more expensive. HRP
    scrap metal 48 likes this.
  6. marine carb.jpg ...and most of them have a black coating
  7. krgdowdall
    krgdowdall
    from Alberta
    A carb for marine application should be UL and Coast Guard approved. Generally not much different but usually has modifications to reduce sloshing and fuel leakage. Generally will have changes to reduce corrosion due to wet salty environment. ( fittings, fasteners, throttle shafts, coating etc. ) Marine engines are usually in a confined space where chance of explosion or fire is greater. Engines will usually have distributor , starter , generator/alternator and flame arrester,( as opposed to air filter ) that are approved for marine use. Any component that could be a possible source of ignition in a confined space, will be a Marine version and will cost you more.
  8. 56sedandelivery
    56sedandelivery
    All the above. I too was going to say most are "painted" with a black coating to prevent corrosion, especially from salt water. Saw on the Gas monkey Garage Discovery Channel show on the latest 32 Ford Coupe, they had a marine carburetor on it. Not sure why they did that, but it stood out. "Get you some of that!". I am Butch/56sedandelivery.
    saltflats likes this.
  9. gimpyshotrods
    gimpyshotrods
    If black is the goal, Edelbrock sells them in black.
  10. aaggie
    aaggie
    Nobody mentioned it but the Marine units are required to have a flame arrester type air cleaner when actually used on a boat. It is supposed to keep any carb backfire from blowing up the gas fumes down in the engine compartment.
  11. daliant
    daliant
    Marine carbs generally have the bowl vents directed into choke area so fuel vapors can't vent into the atmosphere without going through the flame arrestor/air cleaner. Also no provision for any emission ****. And no provision for a vacuum advance.
    Can you run one on the street? Yes you can, no reason why you can't.
    Model T1 likes this.
  12. Model T1
    Model T1
    But why would you? Unless you plan on driving in deep water.
  13. Two shabby
    Two shabby
    I ran a teal painted carter afb marine carb on my truck for awhile. Ran great.
  14. k9racer
    k9racer
    on a Q jet are the flow numbers higher on a 350 boat vs car engine?? Thank you for any answer
  15. stimpy
    stimpy
    nope same carb just with coastguard mods ( overflow vents and some had bowl vent screens )
  16. tguptill
    tguptill
    from Maine
    Most don't have a fast idle cam on them either.
